Question about Nokia 6230i Cellular Phone
Phone hangs, malfunction,buttons not working
My phone keeps on hanging every time and when i press a key it does the direct opposite.
  • 421 Answers
Sir plz hard reset your phone hard reseting code is *#7780# dial this on your phone keypad if problem comes again then update your phone software thnks...........
Posted on Sep 04, 2009
Testimonial: "thank u very much, you 100% solved my problem. -Thank u"
HOW TO UNLOCK A PANTECH PHONE WITH TO MANY PATTERN ATTEMS
1. try entering null as password. (together with your google username) 2. try entering your username without @gmail.com
3. Combine 1 and 2
4. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock 5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.
6. go to recovery (vol down + search +power) and do a factory reset/wipe (it will erase all your files)
Feb 18, 2014 | Pantech Great At&t P9070 Burst Smartphone
How do i unlock my pattern lock on my galaxy s2
1. try entering null as password.2. try entering your username without @gmail.com3. Combine 1 and 24. Call yourself from another phone, answer, without hanging up press the home button, then menu button, settings, try to disable pattern-lock5. Call yourself from another phone, answer, hang-up, directly after hanging up start pressing your buttons like a madman for <30-60 seconds ending with your home button (might take a while to get the timing right). Go into settings and disable pattern-lock.6. Try the normal recover password routine from GMail.com
7. Perform a factory reset. YOU WILL LOOSE all not-synced DATA (SD card will be left untouched).
1-6 are possible workarounds, these doesn't work for everyone but can be worth a try to avoid factory reset. 6. is what should work but hardly never does. 7 - The factory reset always work
Added reference with some additional info, how to factory reset can be found there.Good luck!
Oct 14, 2011 | Samsung Galaxy S GTI9000 Smartphone
My phone got locked after attempting to unlock it twenty times. it went to a gmail account and i dont have a gmail.
Must be an android phone. In which case it makes you set-up a gmail before being able to download apps from the Android Market. Anyway yes now you must start over. This time write down the gmail account.
May 02, 2011 | Cell Phones
My n73 hang i cant use my phone if i replace batery hang again
Formating may solve this.
*You will lost contacts and files on phone, if you do this*
turn off the phone, press 3,*,call(green one) at a time and power on holding the keys ( it means finally 4 keys at a time, dnt laugh , it is way, phone can he hard formatted)
Try untill it askes for the time and country. Pressing 4 keys at a time is a bit tricky so, it is easy to miss one/two attempts, atleast i do.
Oct 09, 2009 | Nokia N73 Cellular Phone
We have a DKT3020 phone system. How do you set
You can go to any display phone:
For the date
1. press intercom
2. dial #651
3. enter yymmdd example ~ 091005
4. press the # key.
5. hang up
For the time
1. press intercom
2. dial #652
3. enter HHMMSS example ~ 170800 in military time.
4. press the # key.
5. hang up
Sep 25, 2009 | Toshiba DKT-2020 Corded Phone
Hanging
software problem..contact service techn
Jun 30, 2009 | Nokia 3120 Cellular Phone
Hang
format mobile by pressing *,3 & green (dial) key together & start cell whie keeping that three keys together, cell will get formated
Feb 21, 2009 | Nokia N70 Cellular Phone
Phone repair
Are you using original keypad? Does all keys work properly? If no consider using original keypad.
Below Keypad in most cases there is a steel button cover on top of Circuit board, or a carbon button on top of circuit board. Try cleaning those contacts. Normally when few keys are pressed together, the phone hangs.
Oct 18, 2008 | Lands Phones
Nokia N73 hanging
it generally hangs when u install new new softwares in it, which is sometimes not compatable with ur mobile platform.
now what u have to do is u have to format ur phone to factory settings that is the only way which is to be done in regard to make ue phone run smooth
sometime when u talk for long hours on ur cell fone , it gets heat up and ur call get automatically disconnected.
u have to reset it which is sometimes dangerous to ur cell phone, it might cause some harm to it.
There r two ways to format ur Cell Phone
1. Soft Core Format
2. Hard Core Format
1. In Soft Core Format u have to dial *#7370#    or   dial  *#7780#     this will format ur phone memory and u have to manually format ur memory card
2. In Hard Core Format ur mobile gets formatted as a tough format,     u have to keep on pressing the three buttons simultaneously(at the same time) for a long period unless u get a screen on ur phone when it asks for the region(ur country).
what u have to do:
1. switch OFF ur mobile
2. u have to press three keys at a time
    Call Button (green key) + * key + 3  at the same time
3. now dont get ur fingers off those buttons , ask someone to switch ur mobile ON (if possible make       ur cell phone placed on some table for stability) (please dont move ur fingers off those three keys       unless u get the screen where u r asked for ur region)
once u got that screen ur cell phone is formatted
NOTE: Formatting the phone with HARD CORE FORMAT METHOD may be harmful if not done in the correct way
Pls Vote for me if this solution works for u
Thank You
Vinay Ramani
India
Sep 17, 2008 | Nokia N73 Cellular Phone
IPHONE HANG UP
press the home keys and power button simultaneously for about 5 secs... it should reboot. :-)
Feb 02, 2008 | Apple iPhone Smartphone
Nokia 6230i Cellular Phone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
