Dell 1908s LCD monitor (new)
Just had a new Dell flat panel monitor installed in my workplace. The colour at the bottom of the screen is several shades lighter than at the top. Contrast and Brightness changes do not remedy this. Had out IT guy out who says: -
Nothing wrong with monitor. users eyeline is not direct therefore any light sources gives the appearance of fading. If you adjust the physical screen position the problem goes.
This is totally incorrect. I've had others in the office confirm that I'm not going totally bonkers and there IS a difference in colour from top to bottom of the screen, whether you tilt the screen, look at it from the side, stand it on a box in line with your eye level, have the blinds drawn, the lights off, and so on.
Any ideas? Seems that someone else has this problem too. Could it be the graphics card? Have tested the monitor as per a very helpful website (with test screen, adjusting gamma, and so on) but its still annoying me.
  • anunn Sep 04, 2009
    Thanks for that Halbrook. I neglected to mention that they'd replaced a couple of monitors in this office so I was able to swap them around, and find that the other monitor is the same, both washing out towards the bottom of the screen. Could it be something to do with the graphics card perhaps?
  • 560 Answers
Return the LCD to seller and ask for replacement. LCD colors should be even from top to bottom. test it with plain color as a background such as blue so you can easily see the faded portion.
Posted on Sep 04, 2009
  • Liza Halbrook
    Liza Halbrook Sep 22, 2009
    are you using the same PC to test the monitors? in my 10years of experience with computer, i haven't seen a video card causing that problem.
    some desktop applications has effects like the "dashboard" of windows vista that is fading the screen from side towards the center.
My TV is turned on and I'm watching it but the status light on the bottom is flashing between blue and orange. Do you know why?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | Dynex 32 in. LCD Flat-Panel HDTV
When i change the dell monitor direction it shows green and blue colour in the both bottom corner..........
Its a blown capacitor in one of LCD screen. If its under warranty contact DELL for replacement.they don't repair those LCD screen. They just replace it.
Jan 26, 2011 | Dell M781P (Black) Monitor
Monitor powers on but screen is black. then a grey stripe appears across the screen. by pressing the leftmost button a faint picture shows the auto-reset? screen, a dell screen, and i can see the main menu...
Hi! I believe that the monitor has come to its end. 6 years is quite long for a monitor. You may have it repaired for there may be blown capacitors that needs replacement but a new monitor will be a great idea. HOpe this helps and have a good one!
May 18, 2010 | Dell E171FP 17" Flat Panel LCD Monitor
My dell P2210t will only light up the top half of
it may be better to bring your LCD to where you bought to claim the warranty. don't try to open the LCD and try to fix it because you will lose the warranty.
Oct 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Screen of LCD Monitor E178FPC has a bright red background colour
I discovered the electronic cable was cracked and replaced it with a new one. This fixed the problem.
Jan 11, 2009 | Dell E176FPC 17" TFT LCD Flat Panel...
Lines top to bottom
I would open it and inspect for obvious sings of burnt components (caps) and reconnect all internal cables. It may be just a loose connection or oxidation on the contacts.
Jun 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell ultrasharp 1704fpt vertical line
i have tried to fix these problem before but no good i did find a web site that will also stat that this can not be fixed but rather they will replace the lcd film at a not so bad price
Nov 04, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Vertical lines on LCD monitor
You have capacitor problem in power supply, if many lines then replace the bigest cap and find anymore that needs replacing. Its an AC filter problem.
Sep 14, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Dell e171fpb lcd monitor
The driver tabs between the LCD panel and it's controller board have failed.
These are very fragile and not repairable for anything in the cost effective range.
Best option is to either find a new panel to replace it, or get a new monitor.
Sep 10, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
