Question about Sewing Machines
The needle on our White model 2999 will not pick up bottom thread - the bobbin may not be spinning
  • Sewing Machines Master
  • 1,388 Answers
Bobbins don't spin, the hook beneath is the moving force.
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Posted on Sep 04, 2009
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
Needle wont pick up bobbin thread
START WITH: SHARP NEEDLE (NEW), GOOD THREAD (NOT FUZZY-LONG STRANDS), ADJUST TENSION OF BOBBIN AND TOP.
1. Check the bobbin area and make sure the hook(pointed thing) and bobbin are all secure.
2. After you have adjusted the tension and reinstalled the bobbin: Extend three inches of thread from the bobbin.
3. After threading the top place the thread under the pressure foot and hold on to the thread. Turn the hand wheel towards you.
4. The needle has went under the throat plate (feed dogs plate) and begins to rise. You should feel the thread get caught and give a little resistance while you continue to turn the hand wheel.
5. The bobbin thread should come up with the needle thread.
6. If this hasn't taken place check to make sure the needle is inserted the right direction and totally pushed in. Retry again.
7. Look at your bobbin while turning the hand wheel. The needle thread should ride across the bobbin case and exit to the top of the machine again.
8. If these have not worked you will need to have your machine timed or the hook replaced.
ATTACHED IS A GUIDE FOR SETTING THE TENSION.
May 30, 2015 | White Sewing 2999 Mechanical Sewing...
Needle thread timing
Bobbin is not moving, sounds like a broken gear, not a timing problem. Bring it in for service.
Apr 03, 2014 | White Sewing 2999 Mechanical Sewing...
White 2037 Bobbin thread not spinning and noticed the needle hitting bottom of bobbin casing
it's sounds like the machine could be out of time & the machine needs to be checked at a sewing machine shop, to find out for sure.
May 10, 2012 | White Sewing Sewing Machines
Singer Model 6233 While sewing the bobbin cas...
If you broke a needle and cannot get it to pick up the thread from the bobbin you need to check your timing. Remove the needle plate and turn the machine over watching the needle, when it is at the bottom of its travel the hook on the shuttle should be right next to or a fraction from the needle. So that as the needle begins to move upward the hook should pass it if it passes to soon it will miss the loop of thread. Check to make sure your needle is installed all the way up in the bar. If your machine is out of time and you are fairly handy, you can retime it. There should be 2 set screws some where behind the shuttle. Loosen them, one loose and one only as loose as need be to turn the shuttle. The needle must have moved upward about 1/16 before the hook is in place to catch the loop. This can be time comsuming, and you will have trial and error. Good luck. P.S. always check for simple stuff before you go for the hard stuff.
May 20, 2010 | Sewing Machines
Needle will not pick up bobbin thread
Chances are you will need to retime it if you have checked everything else, if you email me with your make and model I can attach instructions
Mar 26, 2010 | Sewing Machines
The bottom stitch jamming up
seems like the same problem I haad so I tried changing the needle looking for burrs or bent needle. maybe a piece of broken needle in the bobbin holder. or maybe the fabric requires a certain needle or the needle size is too big for the fabric you are using. or the machine needs cleaning I have started using canned air for this. and then if this fails then you should note the tension position and then try adjusting it one point at a time. always puting it back to where it was to start with good luck
Feb 24, 2009 | White Sewing 2999 Mechanical Sewing...
White 2999
It looks like you have no tension on the bottom thread. Make sure the bobbin thread is in the tension spring, and that there is no lint under the bobbin tension spring. You may just need to increase the bobbin tension, it is one of the two small screws on the tension spring itself (not the one on the end, the one in the middle).
Try an online repair tips site to see what this all means if you need to.
Jan 31, 2009 | White Sewing 2999 Mechanical Sewing...
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Needle will not pick up the bobbin thread
www.whitesewing.com try there web site
Feb 18, 2007 | White Sewing White 3032
Sewing Machines Logo
79 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
