Question about Apple Mac OS X 10.4
I forget username and passowrd in my MAC OS X Version 10.4.11,please findout the solution to restore my username and password.....
    President:
  • 1,566 Answers
Did you lost the administrator password? There is a way to reset it. You will need the install disk in the resetting process. Please make sure you follow the steps accordingly.
From Mac OS knowledgebase:
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue, then choose Reset Password from the Utilities menu (or from the Installer menu, if using Mac OS X 10.3.9 or earlier). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  3. Select your Mac OS X hard disk volume.
  4. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
  5. Enter a new password.
  6. Click Save.
Posted on Sep 04, 2009
I forgot the administrator password, there is a malware protection software I believe. Is there any way to recover password?
You need to restart with original media disk and then you can choose reset password from the apple menu bar.
Mar 14, 2015 | Apple 24" iMac Desktop
Kocaso nb726a
Resetting a password without an additional account Use these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset.
"Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
  6. Enter a new password.
  7. Click Save.
  8. Click the red button in the upper left corner to quit the application.
  9. Choose Quit Mac OS X Installer... from the Mac OS X Installer menu.
  10. Click Restart.
After following these steps, you need to update your keychain so that it recognizes the new password.
If your computer doesn't have an optical drive, connect it to a computer that does using Target Disk Mode, or use the Remote Install Mac OS X utility to start up the computer remotely. Resetting a user's password in Mac OS X v10.5 or earlier If you are using an earlier version of OS X, select your version number below for password reset instructions. Avoid setting a blank password for a user account when using these steps. Mac OS X v10.3 through 10.5.8
  1. Log in with an administrator account. Tip: If you don't know the password of any administrator accounts, see "Resetting the original administrator account password" above.
  2. From the Apple menu choose System Preferences.
  3. From the View menu choose Accounts.
  4. Click the lock button if it appears locked; enter the administrator password.
  5. Select the name of the user whose password you want to change.
  6. Click the Reset Password button or the Change Password button.
  7. Enter a new password in both the New Password and Verify fields, and add a Password Hint if desired.
  8. Click the Reset Password button or the Change Password button.
  9. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Mac OS X v10.2 through v10.2.8 Use Accounts preferences to reset an account password.
  4. Click the lock button if it appears locked.
  5. Select the username whose password you want to change.
  6. Click Edit User.
  7. Navigate to the New Password field.
  8. Enter a new password in both the Password and Verify fields.
  9. Click OK.
  10. If a dialog box appears with the message "Your Keychain password will be changed to your new account password," click OK.
Regardless of how many characters are actually in a Mac OS X v10.2 password, seven bullet characters (•••••••) will appear in the New Password and Verify fields the next time the password is edited. Mac OS X v10.1.5 or earlier Use the Users preference pane to reset a the password.
  3. From the View menu choose Users.
  5. Select the username whose password you wish to change.
  6. Click Edit User.
  7. Enter a new password in both the Password and Verify fields.
  8. Click Save.
Important: Passwords for administrator accounts should not be blank.
Regardless of how many characters are actually in the password, thirteen bullet characters (•••••••••••••) will appear in the Password and Verify fields the next time the password is edited.
Jan 01, 2014 | Computers & Internet
Need to reset password on Mac OS X
If you know your recent password, try this:
http://support.apple.com/kb/HT1274
If you do not know your previous password, try this:
  • Boot from the Mac OS X installer disk by inserting it into the Mac and holding down the "C" key on boot
  • Select your language preferences and then under the "Utilities" menu select "Password Reset" (it may say "Reset Password" instead, depends on the version of Mac OS X)
  • Select the hard disk that the forgotten password is on, then select the username of the forgotten password, you'll then be asked to select a new password
  • Reboot as usual from the hard drive, using your newly reset password as the login!
Thanks,
Charvin
Oct 02, 2012 | demonoid.com
I forgot my password to my laptop how do i unlock it?
Instructions
  1. Put the Mac OS X Install disc into your Apple laptop. This should be the same version currently installed on your computer.
  2. Find the "Install and Restore" icon and click it.
  3. Choose your language and select the arrow button.
  4. Select the "Utilities" menu or the "Installer" menu, depending on your version.
  5. Select "Password Reset" or "Reset Password," depending on your version.
  6. Find your Mac OS X hard disc volume from the "Reset Password" window. If you're the only computer user, there should be only one option.
  7. Select your account from the dropdown menu. Again, if you're the only user, you'll only see one option.
  8. Enter and confirm a new password for your Apple laptop. Click the "Save" button to save your new password.
  9. Find the red button in the left hand corner of the "Reset Password" window. Click it to close the window.
  10. Select the "Mac OS X Installer" and click "Quit."
  11. Click "Restart" to restart your laptop. You will then be able to enter your new password to unlock your system.please remember to leave your comment about this product by saying how helpful it is to you
Nov 24, 2010 | Apple Macbook Pro, -2.4GHz Intel Core 2...
Hi. I turn on the mac and the screen says Mac OS X then there is Name and password. How can I get in to the main screen?
If you do not know the password for the user, you can reset it very easily:
    Note
  7. Click Save.
  10. Click Restart.
Aug 28, 2010 | Apple aluminum 13-inch MacBook laptop-...
Ubuntu 2.86 passowrd problems
Follow the steps bellow:
1) Press escape key (or shift key) during ubuntu bootup proccess ultil you see de grub menu (if you have a dual boot you'll always see it).
2) Choose to boot into recovery mode (it's frequently the second option).
3) Once that you're in the recovery menu choose to boot as root.
4) Once that you're logged into root shell write the following commands
ls /home (it will display a list of users registered in the computer)
passwd username (replace the word username with your userneme [or the])
(then you'll be asked for your new password)
exit
Now you should be able to login using the username and password.
Please leave a comment if you need further assistance.
Regards, Ekeagle777
Aug 01, 2010 | ValuSoft Ubuntu Linux for PC, Mac, Linux
Can't log-in in mac os x
I'm assuming that you have forgotten your password, if so, here is what you need to do.
1. With the unit turned off, press the power button to power-on the mac, but also hold down the "CMD" and "C" keys on the keyboard at the same time. This will tell the Mac that you want to boot into SINGLE USER MODE.
2. Mac OS will now boot into a unix command line shell. From here you only need to remember your username and then type in the following command-line statements.
sh /etc/rc passwd USERNAME reboot
In this instance, USERNAME is the username that you normally login as. The "passwd" command will prompt you to enter a new password for the user called USERNAME.
WARNING: Changing your password this way will wipe out any and all keychain passwords associated with your user account. This is a pain, but better than not logging into the box.
May 19, 2010 | Apple Mac OS X 10.4 Tiger for Mac
Apple G3 starting problem
Resetting the original administrator account password Follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
    Note
Feb 13, 2010 | Apple MacBook Mac Notebook
How do I unlock my macbook,I forgot my password
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 28, 2009 | Apple aluminum 13-inch MacBook laptop-...
I'forgott my computer access code. What to do?
Do you mean you have forgoten your account login password?. If you have press Ctrl > Alt + Delete and enter you administrator passowrd. This should be administrator for username and password.
Once in click Start > Control Panel > User Accounts. Find your Username and change the password. Click Apply
Log Out and you should be able to log in with your new Passowrd.
If not change the password using your Operation System CD.
Oct 20, 2009 | X2 Systemax NO OS AMD Desktop Computer -...
Apple Mac OS X 10.4 Logo
659 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
