Question about Casio Office Equipment & Supplies
I have a Casio fx4500 calculator and have replaced both batteirs with the new ones but it still says low battery everytime i turn it on.what seems to be the problem? Thanks
Seems to be a common problem on this otherwise great calculator that helped me through both high school and university. I've had mine for nearly 20 years and this problem showed up a few years ago. But I remember classmates reported the same problem when it was almost new.
If replacing batteries isn't helping, the problem is most likely caused by oxidation on the springs connecting the battery holder to the main PCB. The solution is as follows:
1. Remove the metal back cover (2 screws)
2. Remove the plastic back lid by removing the black screws (leave the batteries mounted) and CAREFULLY slide the back lid to the lower end (where the EXE button is located). Do not lift while sliding until the lid easily comes off.
3. On the back side of the plastic lid, very carefully bend the the two metal connectors ~1 mm on both batteryholders to increase their tension.
4. Clean the connecting pads on the PCB and the metal springs with de-oxidizer solvent.
5. Re-assemble and your 4500P calculator should be good as new.
Posted on Mar 29, 2012
  • Reza Asgharian Dec 22, 2012
    I have a Casio Fx-4500 since 20 years ago. I opened it as you said. It is all right. Thanks man & Good Luck
  • Rob Weemhoff Jan 24, 2013
    Yes, that worked. Please be aware there are 7 black screws
    Problem Solver:
  • 7 Answers
Hi I have the same calculator..and have the same problem..but it still works Ok..what ever you do DONT hit the RESET button you will loose your Programs..also dont replace both batteries at the same time...
Posted on Jan 17, 2010
    New Friend:
Helps a lot. just remove the back cover and clean the two parts.
Posted on Sep 09, 2017
Contrast Fx-4500 is low : I change the batteries but the contrast is low . plz help me
Posted on Sep 18, 2014
Installing new battery
Turn the calculator over. Look for some small screws that fasten a 1 or cover to the body of the calculator. Loosen the screws and remove cover. You should find button cell batteries. Before removing them make a note of the sign you see on the batteries (+ or -) while they still in place. Replace the batteries with the same model or equivalent ones. Replace the cover.
For more detailed instructions consult your calculator's manual.
Jan 09, 2014 | Casio MS-80TV Scientific Calculator
Hello , I seem to have a problem with my casio fx~9750GII module calculator. When I turn on my calculator , it stays frozen on the MAIN MENU set i.e consisting of RUN-MAT,STAT,GRAPH,DYNA,TABLE,RECUR,CONICS...
Checking the batteries is the first thing one should try. It is possible that for some reason the screen may be too dim.
Reset the calculator by pressing the button on the back. The screen should show the menus. To adjust the contrast you must press the E key (no need to press the ALPHA key for that.) then press F1 to access the contrast setting feature. Press the Right pointing arrow to increase the contrast.
Aug 14, 2013 | Casio FX-9750GPlus Calculator
I have a Casio HR-100TM. I have an
Here is a link to the manual. Be sure to check the box that says your not a robot an then download.
https://www.calculatorusermanuals.com/Casio/HR100TM/Download/491396
Jul 23, 2017 | Casio HR-100TEPlus Calculator
Easy low bat???
On the back upper right is a cover held in place with a screw. You will need a small screw driver to take off the cover. LR44 battery - one needed
With the new battery it is highly recommended to wife it off with a soft cloth first and then place it into the calculator and replce the cover.
NEXT VERY IMPORTANT press the following buttons to turn on for the first time.
Press "ON" "Shift" "9" "3" "="
This will clear it for use again.
Feb 01, 2010 | Casio FX-115ES Scientific Calculator
Casio calculator problem
Sep 04, 2009 | Casio FX-115ES Scientific Calculator
The buttons on my calculator will not work
Back to the original problem. Would it not be a good idea to have the calculator repaired, if cost of repairs is significantly less than the price of a new one? But then, what do I know?
Feb 04, 2009 | Casio FX-9860G Graphic Calculator
Batteries
Turn the batteries over? i guess
Jan 24, 2009 | Casio CFX 9850GA Plus Calculator
The calculator casio CFX 9850GA was not turning on..
first:you must clean battery compatrment in direction of contact point with good contact cleaner from any electronic store near you or from radio shack.
second:clean power switch with contact cleaner.
Dec 21, 2007 | Casio CFX 9850GA Plus Calculator
1,237 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
