Question about Tvone LM-1501R 15" Flat Panel LCD Monitor
NO signal since yesterday in area SY7 0QF on Tv can not get any picture or sound was working before
  • 19,396 Answers
If there is no signal in the area.
I mean, if the problem is extended to more than one TV set, then call the TV provider company.
If the problem is concerning cable TV (eg. NTL, Virgin), then a local node may be faulty.
If the problem is only on your TV, and the TV has no signal, or static, then check aerial, aerial cables, receiver box and signal booster if present.
If you use cable TV, check wires and receiver box.
If you have Sky TV, then check if you have sat signal, check box and cables.
If you do not find anything wrong call TV company.
If instead your TV stays off with power led on or blinking, then the TV is in fault mode (protect).
Try leaving the TV unplugged from power for one hour. If that does not fix the problem, then call the number listed on the owners manual for support, or ring a local technician.
Posted on Sep 04, 2009
No sound
TV was working okay yesterday The screen is showing no signal when I turned it on this morning, I check the cable hookup
Nov 19, 2013 | Olevia LT42HVi 42 in. LCD Television
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
My panasonic viera has just stopped working. I can play a dvd but not watch tv, It says no signal. I have checked all leads and none are loose. It worked yesterday!! What is wrong with it? Please help
What is your TV source? Is it OTA, cable or satellite? Do you use a set top box or a direct coax cable connection? If you have OTA, what antenna do you use?
Try the following depending on your setup:
For all, check if a lightning/surge protector has taken a surge and needs to be replaced. These are placed in the coaxial line to divert a surge that could destroy your electronics. Also try replacing the cables. Check exposed cable for damage.
For OTA, first check that your antenna is oriented to point to the transmitters in your area. (Outside antennas will sometimes turn in the wind; indoor ones can be bumped.) Try a new coaxial cable. If the antenna has an amplifier (or you use a splitter with or without an amplifier), try connecting the cable directly without the device. I've had several amplifiers fail and turn into signal filters (blocking all of the signal).
For any system with a set top box, make sure that the box is on. For satellite, make sure that your dish hasn't moved out of alignment.
To check if it is the Viera TV tuner or the incoming signal, try another TV at the same connection. If you have cable and another TV gets no signal directly connected to your incoming connection, you may need the company to fix the incoming cable. (Underground cables can be damaged by rodents or neighbors who dig without checking for utilities.)
I hope this helps.
Dec 21, 2011 | Televison & Video
I own a Norcent TV model LT-1931. I am a DirectTV
Out of range = the tv receives a signal with a resolution higher than it can display. Connect your DirectTV to another tv and make sure that the signal is one supported by your tv (any SD format will do). If it is then connect your tv to a pc and test the supported resolutions - if none work or the image is bad then the storm has fried its image processor - a repairman should take a look at it.
Jul 29, 2010 | Norcent Technologies2703 27" TV
No picture but i have sound
Sounds like a bad backlight. If you get sound it indicates that the rest of the system is working (decoding the signal).
Contact a TV service provider in your area to get a repair quote.
-=/ Daft Tech /=-
Nov 04, 2009 | Sharp 32C-240 32" TV
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Unusable signal
Had the same problem unplug the tv for hour. Had ours at the tv repair shop and it worked fine there brought it home now we have a great picture but no sound.
Jun 01, 2008 | RCA P52930BL 52" Rear Projection...
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
Tvone LM-1501R 15" Flat Panel LCD Monitor Logo
110 people viewed this question
Top Tvone Computers & Internet Experts
David Payne
David Payne
Are you a Tvone Computer and Internet Expert? Answer questions, earn points and help others
