Question about Dacor Preference PGR30SS Gas Kitchen Range
Oven lights won't work
Tested the continuity of new bulbs, and I can hear a relay click when I press the light control. Is it possible the lights are fused separately?
  • davemont Apr 03, 2008
    Thank you. I don't know what to do next, however.
I had a similar problem; our bulbs tend to loosen over time, sounds obvious but maybe a loose bulb
Posted on Mar 10, 2009
    Sergeant:
    Champion:
  • 362 Answers
Its possible but its also possible no current is flowing through the relay you are hearing.
Posted on Dec 08, 2007
I've shorted out my oven after attemtping to change the light bulb.
most ovens will not operate until you set the clock - doesnt matter what you set it to as long as it isnt 00:00
Nov 30, 2013 | Dacor Preference RSD30 Gas Kitchen Range
Whirlpool microwave model mh1150xmb
please test this steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 19, 2013 | Whirlpool MH1150XM Convection/Microwave...
Blinkers and hazard lights won't work
Could have a faulty relay - fuse or worse wiring problem in that area. Break down the possibles first - bulbs (check & clean), check no wires are loose or broken, then check relay some are located inside car under drives legs (you should hear it clicking as you mentioned). Then check fuses (if unsure which 1 to check always do it 1 at a time if no location details are on lid/cover. Other than that sparky will need to take a look.
Feb 05, 2013 | Air Conditioner Expansion Valve for...
I have a kenmore 90 series elec dryer. Model # 110.64924200. When I turn it on it won't start, however I can hear it click. Like a car turning over but won't fire. Any suggestions? Already cha
the start relay in the control panel is bad,the relays coil is moving this is the click you hear,but the main contacts in the relay are bad there are 4 wires to it 2 for the start switch and 2 for the main contacts
Oct 24, 2012 | Kenmore Dryers
My fog lights won't work but switch shows power, however when hit the switch can hear the relay on passenger side fuse box can hear it click does that need replaced
Hi, if the light on the switch is coming on, the relay is fine. Unless both bulbs are burned out, the problem is in the wiring between the relay and the lights. I recommend you trace the wiring backward from the passenger side fog light to the power box under the hood to see if the wire is cut. There should be two wires coming out of the power box--one going to each fog light. If the wiring looks good, it is also possible that the ground to the lights is bad.
Aug 29, 2011 | 2000 Oldsmobile Alero
My garage door opener works fine. But the lights are not working. Changed light bulbs,Light bulbs are good, I have checked. tried bending the copper tabs in bulb socket out a bit. Still not working. ...
Make sure you are using standard 60 watt bulbs. Some newer type bulbs are causing a problem. If you have a multimeter and are handy it should be no problem to check for 110 volts at the socket and trace the wiring back to the circuit board. There may be burnt or missing traces on the board itself. The click you hear is the relay that controls the lights so you know that is working but there is always the possibility the points are bad.
Jan 16, 2011 | Sears Craftsman LiftMaster Chamberlain...
GE JVM1440BD Microwave hood lights don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
If your relay is bad and you want to replace it yourself, it is part # 3501-001050 and you can find helpful exploded view diagrams of your microwave and order that part here.
Be sure to also do any needed circuit board repair with 30AWG wire to prevent it from doing worse damage if another bulb shorts.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 09, 2009 | GE JVM1441 Microwave Oven
Replaced oven igniter, but oven still not working.
culd be a relay on the clock assy not closing , or the safety valve has gone bad. the valve is checked by checking for continuity through the valve itself( it should have continuity through the two wire connections oon the one side of the vavle). as far as the relay on the clock cosing, with a good valve, you should get 110v to the ignitor when bake is selected( you should hear a faint click from clock a sec or 2 after pressing start)
Apr 10, 2008 | GE JGBP28 Gas Kitchen Range
Cooktop light not working
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 25, 2007 | LG LMVM2075 1000 Watts Microwave Oven
Dacor Preference PGR30SS Gas Kitchen Range Logo
166 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
