Question about Motorola Mobility RAZR V3
I have a problem during IVRS. When I press a choice from keyboard, it doesn't get chosen.For eg. when i want to communicate with my customer care, from recorded message i will be asked to give a choice of 1 or 2 or 3 etc. When i choose the number (press my choice) nothing happens. After 30-40 seconds, i get a message, your choice is not correct. In another case like when i am asked to key in my mobile number or tpin number, even if i keyin that doesn't get passed on and a recorded error message comes. SIM is correct as the same SIM works fine on a Nokia handset.
How do I retrieve message when away from my home
Simply call home using a touch-tone phone:
While listening to the answering machine greeting,
key in your chosen Remote Code using the keypad
on your calling phone and your new messages will
be played for you.
The Remote Code was chosen via a handset at home:
press [menu]
scroll to "Ans. Setup"
press [select]
scroll to "Security Code"
press [select]
enter the two-digit code of your choice,
press [select] ( chirps ) press [END]
Remote *management* of the answering machine is
further described in the owners' manual. To obtain
a replacement manual, you'll need the precise model
number of your phone: this is found on a small sticker
underneath the battery inside the handset. Take this
model number (eg, D1680) to www.manualslib.com
and you can download a free copy of the manual.
Feb 21, 2016 | Uniden Cordless Phone
How to I get a security code for my uniden sect 6 D 1484 cordless phone that I bought at a garage sale?
The remote access (security) code is chosen via the handset:
press [menu]
scroll to "Ans. Setup" press [select]
scroll to "Security Code" press [select]
model number (eg, D1484) to www.manualslib.com
Nov 11, 2015 | Uniden Lands Phones
Casio WK-3500 How to save keyboards/tones
Yes there's a way. Use Registration Memory (I shorten it to: RM) ..
RM have 8 banks and 4 bank numbers. For changing banks, press BANK several times.
Example :
  • choose tone (eg:500)
  • press BANK where you want to store. (eg:1)
  • while holding down STORE button,press registration number where you want to store (eg:3) Release store button. Finish.
Next :
  • choose tone (eg:038)
  • while holding down STORE button,press registration number where you want to store (eg:4) Release store button. Finish.
Anytime you press RM bank 1 number 3 (one key), the sound is 500
Anytime you press RM bank 1 number 4 (one key), the sound is 038.
Notes:
  • RM not only can save tone, but can store style,overall setting live performance,etc.
  • RM functions are disabled while you are using the SMF player, song memory or demo.
  • RM are also disabled while you are using the floppy disk drive.
Jul 10, 2015 | Music
I can't get the @ symbol to appear on screen all I
are you pressing shift + @ key?If you are then the setup language for the keyboard may not be correct eg US chosen for English keyboard. Try finding which key coincides with the @ key by opening notepad and testing each key that can create symbols,commas,hyphens etc
Sep 03, 2014 | Computers & Internet
Printer and computer not communicating
Sometimes to communicate between computer and printer, you have to make sure you have the right name brand printer driver or updated driver then do a test to send a print job from computer to printer. Sometimes you have to make sure your name brand printer is the choice chosen in the control panel of your computer.
Sep 10, 2013 | Kodak Office Hero 6.1
Everytime I hit shift and then the question mark doesn't appear just hte letter e with a accnebt above it
check your regional and language settings in control panel and ensure that the language chosen on all the tabs is the same, normally, this occurs when the language selected doesn't match the keyboard installed (Systems sold in the USA have a USA keyboard, UK an UK one, etc) they keyboard layouts are different and having the wrong language or keyboard layout selected selected gets you the issue you describe.
Sep 10, 2011 | Acer Aspire One Netbook 8.9" Notebook
Casio Keyboard CTK700 The sound does not sustain when the key is pressed for 4 notes. How to rectify the same
sustain is typcially a product of the sound you have chosen, If you have a sustain pedal you can sustain any sound. you may also have some choices on the switches that allow special sustain, but I dont own a casio keyboard (I have yamaha) but they are nearly the same in operation. The easiest way to get controllable sustain is by plugging in a sustain pedal
Mar 24, 2011 | Casio Computers & Internet
Keyboard automatically locks when i press l i had to copy paste the letter l from history. im not pressing windows, i disabled windows button. ive checked safe mode stil. if i press l my keyboard is...
It seems that the keyboard is not communicating correctly with Windows 7 or your operating system, maybe even with your Dell PC, remember that Dells, Compaq's and other major PC companies program their systems so that consumers will only purchase their factory products. First make sure that you have installed the correct drivers for that keyboard, also try swapping with a friends keyboard and see if the problem continues if it stops with a keyboard swap then the Microsoft keyboard is not compatible which seems rare but possible. Good luck.
Jun 15, 2010 | Dell Dimension 3100 PC Desktop
How to get into boot menu ( settings)
hold escape and f1 at the same timewhen you get to the first part of the startup (before the windows loading screen)
Mar 07, 2010 | Toshiba (P000274520) for Portege 7010CT,...
Blocked PUK
above solution is absolutely wrong
if pin (3 attempts) blocked it asks for PUK- this is u can get from network operator just by a call or through IVRS.
if PUK (10 attempts) blocked (call SOS appears). the sim cant be used any more. contact the nework operators shop, handover ur sim so that you get a new sim with same mobile no. this costs Re. 112 to 150
Dec 12, 2008 | Samsung SGH-D900 Cellular Phone
Motorola Mobility RAZR V3 Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
