Question about Fellowes Powershred 420 Shredder
Shredder problems Our Fellowes 420 Powershredder won't shred.  The red light stays on even after I clean the top inside of the shredder. It will work for one shredding and then the red light comes back on and it will only reverse
  • Anonymous Mar 26, 2014
    All of a sudden after shredding the shredder just stopped working. The red light is on when I move the switch upwards although reverse works fine. I checked to see if anything was stuck in the shredder and there is nothing. I don't understand! Please help
  • Anonymous Mar 28, 2014
    Power shredder by Fellowes runs but won't pull paper through to shred
    Scholar:
  • 102 Answers
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Posted on Feb 26, 2008
Motor will go in rerverse but red light comes in foward shred and will not go
I wish the manual said to clean the sensors. I had the whole thing apart. Cleaned her real good. Put it back together. Still a red light indicating a paper jam. I read this post, really helpful! Cleaned the sensors. We are back up and running!
Dec 03, 2013 | Fellowes Powershred 420 Shredder
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Does not shred red light on
Try soaking the cutter blades with hot soapy water overnight thru the feed slot
Nov 04, 2009 | Fellowes Powershred SB-87Cs Shredder
SB-97Cs Full red light stays on
You can order from Fellowes or a dealer like myself. Maybe the unit is all jammed up with shreds in the housing. Try taking the top off and cleaning it throughly. Be careful with the short ribbon cabl.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 19, 2009 | Fellowes Manufacturing Powershred SB-97CS...
Clogged Fellowes P45 shredder
A common problem with all personal shredders is overoiling and the shreds build-up inside the cutter shroud. You will have to remove the top and clean out all of it.
Jun 16, 2009 | Fellowes P50CM Shredder
Green and middle red light go on but motor does not. does not shred
Check the sensors on top and bottom of cutters. Clean with cotton swabs and compressed air. If this does not help, bad sensors or main board.
May 14, 2009 | Fellowes DM8C Cross-Cut Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Powershred 380-c
Possible door switch or the bag full plate under the machine jamed ot switch bad. Also All shredders need the wheels oiled with shredder oil now and then...
Jun 16, 2008 | Fellowes Powershred 420 Shredder
Power switch problem
It sounds as if your Bin full sensors are dirty and need to be cleaned. You should contact Fellowes at 1-800-945-4545.
Jan 15, 2008 | Fellowes Powershred 420 Shredder
Fellowes Powershred 420 Shredder Logo
912 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
