Question about Mustek Bear Paw 4800 TA Pro Flatbed Scanner
Mustek 4800TA Pro Scanner hangs
I have to go thru the Task manager to to make it close. It stars to scan and at the 54% mark the scan bar stop and make a whistle or sa squeeky noise like it's jam but, I can't find no jam. I've load and reload the 3 files the Driver, lib and panel. Countless amount of time but it starts and then stops. Somethime it cancels the scannning by it self.
I cant get my new macbook pro to recognize my mustek Scan Express A3 USB 1200 pro, and i haven't been able to find a driver to fix it so far.
Here is the page to download the drivers you need for the Mustek ScanExpress A3 USB 1200 Pro Scanner:
http://www.mustek.com/mustek/supportdrivers.php
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Mustek Bearpaw 4800ta proII need Vista/Windows 7 driver
Download from HERE (33.7 MB) or HERE (79MB)
These drivers are for Vista.
If you need them for Se7en - in setup.exe file properties point "Install in Vista compatibility". My Se7en accepted...
Jan 18, 2010 | Office Equipment & Supplies
No drivers found for mustek bearpaw 4800ta pro
well, you said that it has xp drivers, so just use those..... If you meant vista, then No....
Jul 28, 2009 | Office Equipment & Supplies
Mustek scanner will not work with vista
can you tell me whyno drivers for vista are available from mustek for my bearpaw 4800 ta pro . Is it possible somehow to get the scanner working ? or is it throw it in the bin time! Thanks Ted
Feb 24, 2009 | Mustek Bear Paw 4800 TA Pro Flatbed...
No HP devices detected. HP Solutions Center will close now.
when it hangs,right click the task bar and open task manager and from the process tab stop the file wrapper.
In device manager click on view and select show hidden devices.
U will see and imaging device keep updating it and
Oct 22, 2008 | Office Equipment & Supplies
Mustek scanner Hang up
Hi leon,
Re-install again the driver of your scanner, machines hangs up because of the operating system got a problem working with it.
Enjoy
tnx
-micro
Feb 10, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Installation problems
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Nov 29, 2007 | Mustek A3 USB Flatbed Scanner
Mustek Bear Paw 4800 TA Pro Flatbed Scanner Logo
267 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Tony
Mike
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
