Question about Casio Exilim EX-S500 Digital Camera
Charging When I put my camera in the charging dock the charging light flashes. The camera won't turn on to take pictures but it will turn on to view pictures. Help?
  • 1 more comment
  • djDivine Dec 09, 2007
    camera works to view pictures, is fully charge. But, when I try to take a picture the lens comes out, goes back in. The green light blinks, but the lens will not stay out to take a photo. this camera is hardly used.
  • Anonymous Dec 10, 2007
    Battery is bad. Called Casio and they are sending a new battery to us. That is what the blinking light means. Problem solved
  • casiohelp Feb 17, 2008
    I have this same problem. Please help
  • 104 Answers
Hi sir , u use 2200mah battreis
Posted on Feb 18, 2008
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
May 12, 2009 | Kodak EasyShare DX4330 Digital Camera
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Won't Charge.
I just had this problem with my camera. all you need to do is get a new battery. But when you aren't using your camera take out the battery. If you don't, you will have this problem again.
Jan 29, 2009 | Casio Exilim EX-S880 Digital Camera
Casio Exilim EX-S880 I put my camera on the charging dock and the orange light comes on. After about 15 seconds it starts flashing. I can't turn my camera on at all. The only way I do is to view them on...
if you try pushing the battery in further it might turn on, if that doesn't work just get a new battery, but make sure to take it out when you aren't using it or this will happen again.
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Red flashing light, constantly.
this is the fix.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Jun 02, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio ex-s770
Call tech support and they will replace the battery for you free of charge.
Mar 25, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
