Question about Compaq Presario M2000 Notebook
I have bought a new battery and adapter and my laptop still wont work...help
  • Roberta Smith
    Roberta Smith May 11, 2010
    what happens when you try to turn it on. and try booting it up with the battery removed and just the adaptor power robert
    Problem Solver:
  • 15 Answers
Does the laptop work with the mains plugged in, and the battery left out?
Posted on Sep 04, 2009
bluegreenash
  • 661 Answers
SOURCE: My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Posted on Oct 09, 2007
  • 38 Answers
SOURCE: Toshiba Laptop wont work unless plugged in.
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
Posted on May 13, 2008
  • 57 Answers
SOURCE: ADAPTER WILL NOT CHARGE MY LAPTOP
Yes, more than likely you will need a new power supply. You can locate them at any computer store.
I hope this solution is helpful. Please remember to rate this solution.
Posted on Feb 11, 2009
  • 31 Answers
SOURCE: compaq evo n600c battery wont work
wrong battery for it or connectoers on battery dirty could be the charger for the battery is bad and shorted battery out
Posted on Mar 27, 2009
Sutibun
  • 186 Answers
SOURCE: Have a Gateway Laptop bought a new ac power
Might be the solder on the jack connecting it to the motherboard . Take it into your local computer shop and have them re solder it unless it is under warranty the i would call Gateway
Posted on Oct 02, 2009
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Mar 11, 2014 | Toshiba Satellite X200-AA3 Notebook
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
HI there, I wonder if someone could help me with the problem I am having with a Medion E1210 netbook. (mini laptop) When it is running on battery, it shuts itself down after, between 2 and 30 mins, even...
did you try the ac adapter those go bad too, the amount of voltage coming out of the adapter is not higher than the batteries out put voltage, then the battery wont charge
try the ac adapter
Oct 09, 2010 | Medion md40298 Notebook
We just bought this acer aspire 5315 lap top brand new charger but battery still wont hold charge even plugged into the wall can anyone help please its for my kids to play?????????????? i have a gateway...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 07, 2010 | Acer Aspire 5315 Notebook
I just bought a Dell latitude model number PP01L. When i plug the power cord into the AC adapter the light on it turns on. but when i plug in the adapter part into the laptop the light turns off and the...
Try it with all devices disconnected from the laptop. Sometimes defective USB devices will cause this. Then try it with no battery. This will isolate the problem for you. If it still happens with no battery or other devices, then the problem is either in the adapter or the laptop. If you bought the laptop new, then contact Dell tech support for help. If not, try a local shop. They should be able to connect another adapter to check the problem.
Apr 21, 2010 | Dell Latitude C640 Notebook
I JUST GOT A GATEWAY M465E NOTEBOOK ON 07' ,IT WONT POWER ON!!! I THOUGHT IT WAS MY CHARGER SO I BOUGHT A NEW 1 FOR MY EXACT MODEL & IT STILL WONT POWER ON! IM TRYING TO SEND IT BACK FOR REPAIR OR A...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 22, 2009 | Gateway M465-E Notebook
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Toshiba laptop wont turn on
Hi, you must remove the battery pack and connect with just the power adapter, and tries to turn on the computer if it operates properly and the battery problem solved
May 05, 2009 | Toshiba Satellite P105-S6104 Notebook
Battery doesn't stay charged
The problem is with the battery. All Lithium batteries last for around 1000 charges or so. Since the laptop is 2-years old the battery needs to be replaced.
I Hope this solves your problem. Kindly Accept my solution.
Regards, Arjun
Apr 01, 2009 | HP Compaq Presario C306US Notebook
Compaq Presario M2000 Notebook Logo
18 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
