Question about D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845)
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Posted on Sep 05, 2009
Dlink 323 password reset
If you still need help resetting your D-Link 323 password, have you tried checking out the user manual? You can get it here:
Link DNS 323 manual
Aug 25, 2013 | D-Link DNS-323 (DNS323) Hard Drive Array
Can't connect to my dns-323
If you disabled the firewall and the Easy Search utility still can't find it, you could try searching for the answer in the device's user manual:
Link DNS 323 manual
Aug 04, 2012 | D-Link DNS-323 (DNS323) Hard Drive Array
I have a DLINK DIR-628 and - starting a few days ago, one of the websites that we visit every day is no longer available. I am certain that it is the DLINK since I have hardwired to the cable modem and...
do a flush dns by going to start > run > cmd
type ipconfig /flushdns
contact your ISP and have them try and ping/traceroute the website your trying to hit.
it could be their dns server is broken.
you can also try changing your dns to 4.4.4.4 which is google's dns server and see if you can reach the website your trying to get to.
May 08, 2011 | D-Link DIR-628 Wireless Router
I have a panasonic G20 TV with wireless connection to my network. there no problem accessing vieracast (the internet connection is working). I have a NAS (DLNA) drive connected to my router. PC's find...
i am having a similar issue with my Panasonic G20 and Dlink DNS-323 NAS drive. I installed Twonky 6 and it worked for a short while and now does not even list the server in the list of the TV. Anyone else know what NAS drives are compatible with this TV?
Mar 09, 2011 | Televison & Video
Dns-323 automatically shutdown few seconds after startup
had you found a solution ? i'm front the same problem :(
Aug 01, 2010 | D-Link Dns 323 2-Bay Network Storage...
Easy Search does not pick up the DNS 323
This may be problem with your personal firewall on Windows workstation where you are running the Easy Search utilit. Try disabling the firewall while you run it.
Mar 19, 2010 | D-Link Dns 323 2-Bay Network Storage...
I have a D-Link DNS-323 Hard Drive Array and many times I cannot access it but have no explanation of why it works sometimes and others it does not. The error I get is 'Microsoft Windows Network: The...
What is the firmware version of DNS-323? Many bugs were fixed in recent firmware revisions. You can see your version in the top right corner in the web interface after you log-in. See on the D-Link website if there is a newer firmware available.
When it doesn't work, what you have to do to make it work? Reboot windows? Or reboot the DNS-323? It can also be issue with your firewall or Windows configuration. Which Windows version do you use?
Jan 31, 2010 | D-Link DNS-323 (DNS323) Hard Drive Array
Hello, I just bought DNS-323 and trying to start up it. I?m using one hard drive Seagate Barracuda 7200.10 ST3500630AS SATA 3G HDD 500G. I installed it in HDD1 slot and start the system. DNS-323 received...
I read that there are problems in some applications if you use only one disk in the 323. Try to move your disk to the other slot to see if this fixes your problem. Alternatively (if u have the money), you can try buying another hard disk of same brand/model and install it on the other slot.
You can then try setting up your device as a RAID1 or bigger (not recommended) JBOD configuration
Nov 22, 2009 | D-Link DNS-323 (DNS323) Hard Drive Array
Mapping of D-link DNS-323 drive doesn't succeed.
I had the same problem when I was attempting to map the drive using the hostname of the DNS-323. I solved the problem by typing in the IP address instead. Do the following:
1. Login to the DNS-323 as admin
2. Make sure you use static IP's to make sure that the address does not change in the future.
3. Go to the drive mapping page and use IP address instead of hostname in the drive mapping (e.g. \\192.168.1.1\Volume_1)
4. Make sure you use a valid username and password.
5. Check the connection configuration by clicking on the Test button.
You should get a successful outcome, otherwise check all the settings again until you are successful
Nov 20, 2009 | D-Link Dns 323 2-Bay Network Storage...
Can not access Dlink DNS313
When you said you tried resetting, did you mean you clicked on the reset button inside the hardware or did you mean you just rebooted?
* If you clicked on the rest buttion, then you need to configure again from scratch. Not sure if your data will still be available though.
* If you just rebooted, then the problem may lie in your LAN configuration. Do the following:
1. Try to ping the device using a PC connected to the same network.
2. If you are using DHCP, your device may just have been assigned a different IP. Try to ping all devices in your network or use a network scanner (e.g. SoftPerfect) to find out the IP address given to it.
3. Once you get the IP address, assign a static IP address to your device that is beyond the DHCP scope. This will ensure that your IP does not change and you will not have a conflict with DHCP assigned IP's.
Dec 29, 2008 | D-Link DNS-323 (DNS323) Hard Drive Array
D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server (S6070845) Logo
780 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
