E5 is error code 5.
It means the water is not filling correctly (or the sensors are not noticing the fill correctly). Make sure the water supply is on and hoses are not kinked. If all water supply is ok, then the valve(s) may be bad. They are expensive so best checked and replaced by a technician.
UE- means an unbalanced load in a washing machine.
le- means make sure water supply inlet hose is on. check inlet hose for any kinks or bends in the line
that could prevent the machine from filling properly, check and make sure the water supply is on
completely and not partially. check inlet filter for buildup of mineral deposits. clean filter with small
brush. make sure that machine can drain properly. good luck!
Go into your "router" configuration under wireless, change the channel it operates on. It is possible some new electronic in your house or neighbor is causing signal interference on that channel causing you to drop your connection periodically.
some time web site not working..i mean to say system not reply your request.....if you want better chat option ...You should download yahoo messenger ..clink on this link for download......http://messenger.yahoo.com/download/
If your friends list doesn't come up, it should mean that you're not connected to the PlayStation Network. Right now the Network is experiencing some problems, and I'm having a lot of trouble signing in as well. If you go under the Network column in your XMB and select "Sign In" it should try again to connect. Once you're connected, your friends list will appear.
