Question about HP LaserJet 5200tn Printer
Hp laserjet 5200tn no display
A laserjet 5200tn printer does not show anything on the control panel when turned on.Some activity can be heard in the printer.It works sometimes after several attempts.
    President:
  • HP Master
  • 1,996 Answers
Is it in sleep mode, or is this some other issue? Scroll down to the resets submenu in this article .
In fact, you might try simply resetting the printer, to try and clear the memory, but if you choose to do so, make sure you have printed a configuration page beforehand so you have all the info needed to set it up again.
Or you could try an online diagnostic session with HP, available here.
Finally, your model home support page with other troubleshooting options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 04, 2009
  • efs_perpends
    efs_perpends Sep 04, 2009
Hplaserjet 5200 rfu error problem
1- we want to instal printer to local computer
2- the computer cant sport the the usb line of hp laser jet 5200
3- the printer menu is locked and we can't change it in the printer screen show the rfu error for upgrade
Jun 11, 2012 | HP LaserJet 5200tn Printer
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
HP cm1312nfi control-panel display WHITE, it still...
Try doing a hard or reset or nvram:
1. Turn the printer off, disconnect the phone line
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If the lcd does not display anything contact hp or a local service provider as there is a definite power failure.
Al
Eliteprintersolutions@gmail.com
May 20, 2010 | HP LaserJet CM1312 All-In-One Printer
While printing there is a noise
Maybe go to a local store and try a display model of the same printer and see if it makes identical sound. If it doesn't make the same, contact whoever you bought from to see about warranty or refund. Can also contact HP customer service for advice.
Sep 16, 2009 | HP LaserJet 5200tn Printer
HP CLJ 4700 empty display, no answer
When the display is light and printer is ready for printing but does not pass pages:
There are still jobs in the memory buffer of the printer.
This could be solved by pushing the oval select-button.
Notice:
1. Entering the oval select-button also activates the new control panel settings (when they have been changed).
2. Printer control panel settings could have been changed over a network cable: checking the settings is a next step when problems do
disappear.
Aug 12, 2009 | HP LaserJet 4700 Printer
Hp Lasejet 5200tn new printer ligh print Problem
Did you take the seal off the toner? Or possibly a bad toner.
-Carl, please let me know if this helps.
Jun 26, 2009 | HP LaserJet 5200tn Printer
HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Mar 19, 2009 | HP LaserJet 4250n Printer
CONTROL PANEL BLOCKED LJ4345
Friend,
Yes, there's a firmware that should fix this. It can be found HERE:
Hopefully this will do the trick.
//Al
Feb 09, 2009 | HP LaserJet 4345mfp Printer
Need to find a service manual for an HP LaserJet 5200TN. Do you know where I can download the manual?
You can request a manual from this site just copy and paste into your address bar
http://office.manualsonline.com/manuals/mfg/hewlettpackard_1/hp_laserjet_5200tn_q7545aabe.html?ct=support
Dec 18, 2008 | HP LaserJet 5200tn Printer
HP LaserJet 5200tn Printer Logo
778 people viewed this question
Seeker5211
Seeker5211
