Question about Brother MFC 6490CW InkJet Printer
My brother MFC490CW is not playing nice with windows 7
When I had Windows 7 32 Bit installed on the computer, I was able to properly install the MFC 490's driver suite without any trouble, was able to check everything on the computer. When I upgraded to the 64 bit windows, I was unable to use the disk, and the printer no longer appears in a printer list when you try to set up wireless printing with the bundled software. However Windows 7 does find the printer, and I can print (but I can't check ink levels on the computer), I also had to trick the software into recognizing the scanner (the control center [software] still can't find the printer, in spite of the printer being installed and working elsewhere) but I would prefer to have it all working properly, within the control center, where I can actually check ink levels, and where it actually displays printer status. I have seen similar problems on here for other models, but so far no solutions. Please help!
I have a similar problem except it said it does not contain drivers for your computer operating system. I updated the drivers on brothers solution center, it said decompession successful and everything but still the same thing. what should i do?
Posted on Jan 14, 2010
I can't install my Brother MFC6490CW printer onto my laptop which has windows 7. At the setup stage an error message 0X00000704 unkown port appears. I have turned off my AVG anti-virous and my windows firewall. I have installed the printer onto my PC which has XP.
Posted on May 22, 2011
    Novelist:
  • 157 Answers
Visit the Brother website
http://www.brother-usa.com/
See if you can find an updated driver for your 64 bit Operating system . Download it and save it to your desktop. Remove the old driver then install the updated one this should fix the problem. But if you can't find an updated driver, contact Brother.
Posted on Sep 04, 2009
  • Charles Loux Oct 24, 2011
    I tried the Brother website as well but nothing worked so I went to the Microsoft website and it stated that it was compatible with Windows 7, 32 and 64 bit so I started to file a report disputing this claim. As I was continued filling out the report the printer cycled on and started working. I then sent a document to the printer and everything was fine. I went back to the MS website and cancelled the report.
2 Suggested Answers
trikha_karan
  • 66 Answers
SOURCE: My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Posted on Nov 10, 2009
I downloaded printer driver for brother mfc240c, but even after install, I get a message that says the driver isn't installed.
Open the printer and scanners folder an delete all the devices (Brother Printer, Brother Fax, Brother PC-Fax if installed). Point to device an right click the mouse button.
Restart the computer.
Download the software from Brother Solutions Center. Download the whole suite not just the drivers. Make sure you select the software that is compatible with your version of the OS :Windows 7 32 bits, Windows 7 64 bits, Windows 8 32 bits, etc.
Install the software. If you are going to use a USB cable to connect the MFC to the computer, install a local USB printer. If you are going to use Ethernet network cable, install a wired network printer, and if wireless connection then install a wireless printer.
If you have problems finding or attributing an IP address to your printer (for Non-USB connections) there is Brother program that helps you attribute an IP address. You will find it on the same page as the software suite on Brother's site.
Nov 07, 2013 | Brother Multi-Function Center MFC-240C...
Can not install the drivers for Brother MFC 7340 printer - i no longer have the CD
Here is a link you may be looking for: Link
This has the drivers for Windows 2000/XP/Vista/7, both 32 bit and 64 bit. If in doubt, use 32 bit.
Hope this helps!
May 25, 2011 | Brother MFC-7340 All-In-One Laser Printer
New computer is Windows 7 - 64 bit Printer is Brother MFC-8820D. Printer works fine - computer does not recognize the scanner feature of the MFC. Have tried both USB and LPT1 connection to the new...
I lost my network fax and scanning when I upgraded to Win 7 as Brother had no support for Win7 and this printer. Very disappointing.
However, I recently downloaded the MFC-8370DN install package from the Brother website and installed it on my Win7 64 bit Asus laptop. The installer couldn't find my MFC8820DN, but I manually entered the IP address (192.168.0.100 in my case). The install completed cleanly, after a reboot I can now start Brother Control Centre 3 and scan and fax from my 8820DN over the network. All good, no need to buy a new printer just yet...
Apr 26, 2011 | Brother MFC 8820D All-In-One Laser Printer
Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Mar 28, 2011 | Office Equipment & Supplies
HOW TO INSTALL THE PRINTER TO MY WINDOW 7 LAPTOP?
Download your drivers from here:
http://welcome.solutions.brother.com/bsc/public/us/us_ot/en/dlf/download_top.html?reg=us&c=us_ot&lang=en&prod=mfc240c_all
Note: at first you must check - do you have 32 bit or 64 bit operational system to download proper drivers!
Click bottom left Windows logo -> Computer -> System Properties. Look at "System type: xx-bit Operating System".
Sep 27, 2010 | Brother MFC 240C All-In-One InkJet Printer
Hi i have a printer (brother MFC-235C). I changed
No there's no specific drivers for windows 7 either 32 bit or 64 bit, it'll automatically install the device with the default drivers.
details here
If there's a problem with your cartridge or cartridge ink level indicator, then you better clean the cartridge contact points and the contact points on the printer.
Good luck
Thanks for using FixYa.
Jun 25, 2010 | Office Equipment & Supplies
We have a MFC 7440N at work. I have Windows 7. I
did you install the full suite for your printer OR just the printer drivers?
I believe if download the full suite, uninstall the old software from control panel 's add/remove programs, then reinstall the complete software you should be up and going again.
the software download is here: http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=mfc7440n
make sure you select the correct operating system as there are both 32 and 64 bit drivers. and make sure you pick the "full driver & download package.
there is also an uninstall tool at the bottom of the page to remove any older software/drivers you may have previously installed prior to installing the new software.
Apr 02, 2010 | Brother MFC-7440N Laser Printer
I want to install my brother MFC-5840CN onto a new laptop that is running windows 7. It will not install from the disc and says to visit the brother solution centre that does not give me any help. How can...
http://welcome.solutions.brother.com/bsc/public/eu/gb/en/dlf/download_top.html?reg=eu&c=gb〈=en∏=mfc5840cn_all
Click driver, then the windows that is closest to windows 7 (Vista) 32 or 64 bit, depending on what windows7 you have installed. Vista is very close to Win7 so a vista driver may well work.
So select Driver, then Windows Vista in the box below (or Windows Vista x64 Edition) depending on your current bit, then select English and then search.
On the next page click to download the Full Driver & Software Package.
This may well help you, and the drivers here will be much newer then whats on your disc, as will be the utilities.
Hope this helps you.
Jan 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC 6490CW InkJet Printer Logo
1,890 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
