Question about Acer TravelMate 290 Notebook
I have a TravelMate 290. It has started beeping when I switch it on. Two short and one long beep. Won't stop until I hold the power button down to switch off and start again. Please help! What is it trying to tell me? Nicole
    Genius:
  • 1,341 Answers
Are you able to get into bios screen?When it starts up it performs POST(power on self test) and it does this beep when there is something wrong..It may be a faulty memory or even a low battery sometimes,unless it is on charge and battery is charging or has charged..Hope this gives you an idea...
Posted on Sep 04, 2009
  • 106 Answers
This beep indicates that the ram is bad and it needs replacement
Er-290 wont stop beeping
Step 1:
The beeps are post during post the very first work is done by the ram, all the memory in the ram is first transferred to the hard disk, and remains 1 short beep : Normal POST - system is ok
2 short beeps : POST Error - error code shown on screen
No beep : Power supply or system board problem
Continuous beep: Power supply, system board, or keyboard problem
Repeating short beeps: Power supply or system board problem
1 long, 1 short beep : System board problem
1 long, 2 short beeps: Display adapter problem (MDA, CGA)
1 long, 3 short beeps: Enhanced Graphics Adapter (EGA)
3 long beeps : keyboard card
http://www.pchell.com/hardware/beepcodes.shtml
Feb 20, 2013 | Computers & Internet
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Hi, I have a Bosch undercounter freezer and it won't stop beeping!!! All the lights flash whilst beeping, the lights are under the super freeze button, mute button and the temperatures. If I hold...
The beeping is a signal that the fridge has not got down to, or holding temperature... You may have a thermostat or gas system fault. Check and see that the fridge has actually got cold.
Jul 31, 2011 | 2007 Harley Davidson FLHX Street Glide
Hi my name is mike and have a serious problem with my playstation 3 well my system froze up in the middle of a game so i turned it off to reset it and now a red screen comes up and says a serious error has...
Try to start to the system in safe mode to check if this will resolve the problem.Safe mode is available to PS3 system software version 2.60 or later. To do the safe mode follow these steps:
  1. Verify that the power indicator on the PS3 system is solid red, and then turn off the MAIN POWER switch.
  2. Turn on the MAIN POWER switch, then touch and hold the power button.
  3. Keep touching the power button even after you hear a short beep after 5 seconds.
  5. Touch and hold the power button again.
  6. Continue touching the power button even after you hear a short beep after 5 seconds.
  8. As instructed by the on-screen message, press the PS button to start up in safe mode
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
Cant get the salt water pump started
Hold the left button until it beeps. Hold the right button until it beeps. You should see flashing 00. Set the time by moving the right button. Then hold down the left button for a long beep. Then hold down the right button for a long beep.
May 29, 2010 | Intex Automatic Salt Water System for ...
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Acer Travelmate 290 laptop beeps all the time
try to turn off the alert sound on connectivity and time event from windows.
hope this works.
Jul 11, 2009 | Acer TravelMate 290 Notebook
Beeping
If the system beeped and is a long one, but you did not get it to boot i would suspect that the processor has failed, but if its a short beep and you can get into the bios, check the date and time as if it is incorrect, if so, it may simply be that the cmos battery needs replacing on the motherboard. Beep codes can define allsorts of differnt things, so without knowing the motherboard make, it is hard to pin down to a specific fault so applogies if incorrect.
Jun 06, 2007 | Acer TravelMate 290 Notebook
Acer TravelMate 290 Notebook Logo
275 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
