Question about Sony KEP37XS1 37 in. HDTV-Ready Plasma Television
As I turn on TV it keep automatically switching between channels and I cannot fix one specific channel. I tried to disconnect/connect and it continues to do so
Maybe ur tv is on search channel mode. check the menu panel and look for the tv's browse channel option turn it off. also read ur owner's manual about how to browse channel automatically.
Posted on Sep 04, 2009
When I turn the receiver on the the TV automatically plays in stereo mode. If I channel up it will switch to Dolby surround. How do I get it to start up in Dolby surround?
Not all channels broadcast in Dolby. The receiver will automatically switch to Dolby if it detects a Dolby signal. I can't be specific about the receiver as you have not stated a model. A lot of the switching depends on what sound setting the TV is set to broadcast. What settings you have set the receiver to. Plus the connections between the two. For best sound quality connect them by optical cable if both support it.
Jan 31, 2016 | Audio Players & Recorders
My channels on my tv keep changing on its own everytime i turn on the tv. i tried new outlet, new batteries, and turned on manually. and left it sit for a week. but the channels keep changing on there own...
defective tac switch on the manual channel button, it is found inside under the button, this causes the program to change channel because the connection of the switch is shorted..normally it should be N.O. (normally open)...try to replace a new tac switch..
Feb 12, 2011 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
Panasonic viera 42 inch plasma, comcast digital cable. screen goes totally green. switch to comcast guide, green disappeared and switched channels, then back to original channel and all was normal. it...
It sound like you are using a component video connection to the TV, which is of variable specification. Try a different type of video feed from your Comcast box
Jan 27, 2018 | Panasonic Viera TH-42PX80U Plasma TV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
TV channel sound from a different channel
I just unplugged the tv from the power source and disconnected the cable connection and then reconnected them back after sometime. The TV started auto programming after turning on and that resolved the problem.
Oct 18, 2009 | RCA Televison & Video
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    Sony KEP37XS1 37 in. HDTV-Ready Plasma Television Logo
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
