Samsung Progressive 100hz SP43W64P picture has gone out of focus on Right & Left side of screen?
    President:
  • 3,130 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Screen looks 3D Colors don't line up One or more colors can't be adjusted when using the convergence menu. Screen is bowed or warped. Here is a quick test.... Using your original remote go-to the TV settings then go to the convergence section. Try to adjust the red and then the blue convergence. You should be able to move them up, down, left, and right. If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem. Solution #1 you need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for most models. If you don't see kits for your set send them a quick note under the contact us button please, you will get an answer within 24 hours or so.(excluding holidays Good Luck
Techman
Posted on Sep 04, 2009
I have a Samsung HLP5063 DLP tv. After replacing the bulb and cleaning the inside of the TV, the picture is out of focus on left side and in focus on the right ( varies slowly across the screen). Does...
If you wish to get some details about this, check the site linked here. Adjustment to be done after lamp replacement to DLP TVs are given in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Samsung DLP HL-P5663W 56" TV
My samsung dvd-sh855m has no picture, only sound. there is no picture at all so I cannot even set the machine up. When I put a dvd in I can hear it but the screen stays black
Press the 'pscan' button on the front of the recorder 3 times and the picture will come back. This is a little sod as you only need to catch the pscan button once - if your TV doesn't support a progressive scan your picture has gone....
May 04, 2010 | Samsung DVD-HR720 DVD Recorder
Good evening, I've gone through the manual and I can't get my TV to show 100hz (always 50hz), also on some channels I cannot get the picture to fit the screen (it's 32''). Any help would be greatly...
Well, first the 100Hz issue. Your TV will display a descriptor or the signal it is receiving, not a descriptor of the picture you are watching. Your TV panel has a native resolution and frequency. In your case, that frequency is 100Hz. Everything, like it or not, must be converted to 100Hz for the TV to work. In your manual, you are simply adjusting setting which smooth the picture and make it flow better than it would at 50Hz. This feature is slight of hand and is probably working just fine. As for the picture fitting the screen; HD programs fill the screen of HD channels.... SD (Standard Definition) programs use black bars on each side when on HD channels. You can use any available wide or picture size feature your TV may have to stretch the picture. You may be unable to stretch the picture, due to restrictions (some TVs will not resize HD formats).
Mar 15, 2010 | Televison & Video
Sony KP 51 HW 40 Blue Lines
Some of these sets had problems with bad picture tubes; there is something you can do to try to correct this without replacing any parts.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You may have a bad blue picture tube but there is a way to deal with this first----the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input clip_image001.gif with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
If this cures the problem you may only be buying yourself some time----if the blue picture tube is bad sooner or later this trouble may return----I have seen sets where this was adjusted and the set worked for a year or more with no repeat of the trouble----replacing the blue tube would likely cost you 400 - 500 parts and labor.
I do this here for free so if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 01, 2009 | Sony KP-51HW40 51" Rear Projection...
Fading blue screen
You may have a bad blue picture tube but there is a way to deal with this first---This is a 2003 model ---I did one of these with the same problem a week ago---the set has a black plastic block with six controls---three are Focus(red,green,blue) the other 3 controls are Screen controls(red, green, blue) Someone has to remove the entire piece on the front of the set below the screen(usually a plastic part) most of the time it is secured with 3 screws on either side of the set in the back; once you remove the screws the entire piece should pull out(pull from right to left(it will not fall off or come out easy--it is held in with several large plastic pegs) With it removed there is an inspection plate with 4 screws-----the screen/focus block is behind it.
You need to look very closely at the block to identify the focus versus screen controls----one row left to right will be marked Focus and the other row left to right will be marked screen------YOU need to locate the Blue Screen control(they are black like the block) With the set on(be careful) go to a video input with nothing connected---if you see a blue screen as well as the input number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is gone.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE LET ME KNOW- I am here to help people.
SD TECH
Oct 06, 2009 | Sony KP-51WS500 51" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Picture distortion
Sounds like convergence is off. Need new Convergence amps. Could cost a couple hundred. Check around. If it has an auto converge or manual converge try that first. Check menu
Apr 08, 2009 | Televison & Video
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
Feb 04, 2009 | Samsung DVD-V3650 DVD Player/VCR
Red lines, Help??
when you replace the convergence amp board. u usally have to go into setup. or service mode and manualy converge the set. these settings are what perfect focus basis it reconvegence on. sort of the factory settings. these faint lines may also be a red crt overdriving too
Jan 03, 2008 | Samsung HCN5527W 55" Rear Projection...
Televison & Video Logo
339 people viewed this question
Top Televison & Video Experts
Electro Med Services...
