Question about IBM ThinkPad R50e Notebook
There are lines on my screen , lines of different
There are lines on my screen , lines of different colours like red, blue, yellow, there are almost 35 lines so how can i solve this problem plz guide
    President:
  • 1,447 Answers
Your laptop TFT is problem change it
Posted on Sep 04, 2009
  • Sazeed Computer
    Sazeed Computer Dec 02, 2009
    Please check Ram,or Video memory
Diagram for multi plug, elkavox 83 generater to accordion
one wire coloured red is connected to the live line(soldered)
second wire blue in colour is connected or soldered to the neutral line.
third wire coloured green and yellow is connected to the earth line.
Jan 27, 2012 | Electrical Supplies
I am trying to install a Panasonic stereo to a mitsubishi mirage 1996, trying to find wire diagram for vehicle, the one I found on net was completely different from wiring colours in vehicle.
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Driver's Pillar Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
May 14, 2011 | Mitsubishi Mirage Cars & Trucks
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
I have a VT465 and the projection back ground is yellow and I can't get it to be white
If you are talking about the actual image that is coming from a laptop being yellow instead of white, then this is caused usually by a bad signal cable running between the computer and the projector.
To be more specific: All colours in a projector get made up in some way between red, green and blue. White is all of these colours at maximum, yellow is made by red and green at maximum but no blue. If your image is Yellow when it should be white, then the blue signal information is not reaching the projector. This can also happen within the projector or computer itself but is less likely. If your using a VGA cable (15 pin cable) then blue is run through pins 3 & 7 (positive and negative respectively), see if your cable is either missing these pins on either end or if they are bent, although it's more than likely within the cable itself. You can test this theory easily by trying to put something blue on screen, if the blue signal isn't getting through then it'll appear black.
If changing the cable doesn't solve the problem try testing the computer by trying to use a different one, and test the projector by plugging in a monitor or another projector.
If you are getting a yellow screen without sending signal and just trying to get the "no signal" or "no input" screen white, then this won't be the case.
Mar 24, 2011 | NEC Office Equipment & Supplies
I have a 2002 Suzuki Swift 1.3 and I need the colour coding for the car stereo. This is how it looks like looking from the back of the connector. The top colour is the main colour and the bottom is the...
why post non usa cars to USA forum>????
hint, we dont have M13 here. (EPA ******* here)
then not telliny your county.
why"?
my guess is you think all cars same, all suzuki same world wide and all suzuki have 1 radio.
sorry that don't fly.
but most posts here are just like this, hopeless.
wild guess 1:
here is our last swift, sold USA.,(not a m13 for sure)
wires
MAin set; and speakers last.
wht/blk, = ign. on. power 12v
white = memory , hot all time to battery via fuse, station memory
black = ground
red-green = illumination
red-yell = park lamps on, lighting,.
and below is speaker.
this is year 2000 last car sold here,
Mar 13, 2017 | 2001 Suzuki Swift
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
DVD Player connection to the tv... Theres three different colours on each side (red, white, and yellow) I already got it hooked up to the tv but the problem is that to hook the other end into the DVD...
Red is usually the left channel audio, white the right channel audio, and yellow the video. Look for something to the effect of "audio out" and "video out" on your DVD player.
Jul 07, 2009 | Norcent Technologies E-DVKIT003 10.2 in....
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
IBM ThinkPad R50e Notebook Logo
214 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
