Toshiba Qosimo G45 Screen goes dim but is still on.
I can't see the screen unless I hold a flash light to it. It will stay on only for a few seconds. From what I've found through research the sensor for closing the laptop is stuck. Supposedy there is a pin to tap to get it to work but I can find no such pin. Just got the computer today and Toshiba tech. support was no help at all!
    Sergeant:
  • 324 Answers
Good morning, Chase!
I'm not familiar with that particular model, but will try to help. Most laptops have a switch that is activated when you close the lid. These switches are normally located somewhere around the hinges. What you are looking for may be a small area (1/8"x 1/8" or smaller) that has a pad, or something, that can be depressed. That pad may be level with the surface, or located down in a depression or hole. It may be square, round "D" shaped or whatever. One hint is to look for a projection of some type that is normally located somewhere on the bottom part of the LCD bezel and that projection will activate the switch. I have seen them mounted on the lower outer edge of the lid, but that is usually found only on older units. And yes, it can be interesting to find some of them. ut, rest assured that it is there, somewhere..
I realize that this is kind of generic, but hopefully will be of some help.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Dec 08, 2007
My screen brightness its lees
Then brighten it. You brighten it by Holding Down either FN, CTRL or DEL key + Hit the corresponding key for brightening the display.
For example on my computer I press and hold the FN Function key while I hit the UP Arrow key to brighten the screen.
The brighten/darken keys normally have the icon of a circle with sprockets around it like the sun or it looks like a washer that goes between a screw.
Mar 23, 2012 | Toshiba Qosmio G45-AV690 17" Laptop PC...
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
My toshiba satallite p200-1ee laptop is not charging. Battry life left: 40% When on: The Charging light blinks 3 times every few seconds and the screen dims with it. When off (But pugged into mains): the...
If you plug the charger into the computer without the battery and the laptop runs fine, then I would suggest to you that your battery is failing and will no longer accept the charge. On the other hand if the laptop will not stay running or acts strage and the screen dims and gets bright, then I would suggest to you that the charger's built in voltage regulator is failing and will damage the laptop if it continued to be used. A bad charger will also permenently destroy the battery condition.
Dec 01, 2009 | Computers & Internet
No power to TV - No Screen - No sound
check the fuse, I found my had blown and that's what it was sort of. Light doesn't flash any more but nothing comes on
Aug 10, 2009 | Toshiba 32HFX72 32" TV
The screen is dim and goes black everytime i touch the wheel
Here is the link to the user manual - in the Settings Menu, there is a way to change the frequency with which it dims:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
Mar 24, 2009 | SanDisk Sansa e200 MP3 Player
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Robert
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Dell AXIM Screen
First, to dim/undim the screen, hold down the power button for a few seconds. A quick press will turn it on/off. Also, when dimmed, if you tap the screen, it should be fully lit. FYI...to change the brightness in either the plugged-in or battery mode, hold in the scroll dial on the left-hand side and press the navigation button (big round one on the front) either up (brighter) or down (dimmer). As for the time, tap Start >> Settings >> System (tab) >> Clock and see if your time is off by 12 hours.
Sep 14, 2005 | Dell Axim X50 Pocket PC
Computers & Internet Logo
199 people viewed this question
Alun Cox
David Payne
David Payne
