Question about Fuji FinePix S7000 Digital Camera
Set s7000 white balance
How do i set white balance on fujipix s7000 camera
    Novelist:
  • 109 Answers
Navigate through the settings menu's until you find the one that addresses the white balance. Either leave it set to automatic or experiment with different settings until you are pleased with the results. If this was helpful, please rate.
Posted on Oct 04, 2009
Pink cast to all images now
It sounds like your white-balance is off on the magenta side of things. This could be caused by a number of factors, though I would explore your camera's white balance setting to make sure it's set for the right lighting situation. If changing your white balance setting fails, it may be a more serious issue with your sensor or other camera hardware, requiring a professional to repair it.
Jul 08, 2013 | Fuji FinePix S7000 Digital Camera
I could not found white balance in shooting mood
You can set the white balance only in one of the P, S, A, and M modes. In the point&shoot modes the camera will always automatically set the white balance (and just about everything else).
In one of the PSAM modes you can set the white balance in the Shooting menu. Full details are in the "White Balance (P, S, A, and M Modes)" section of the manual (page 70 in my copy).
Mar 22, 2012 | Nikon D40 Digital Camera with G-II 18-55mm...
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
Picture on scree is black and white. How do i get colour
Your camera's Colour has been set to "Black and White". Select the camera icon on the power selector, and 'auto' on the mode selector. Press the menu button, and use left and right to find the "Finepix Color" setting. Use the up and down to select "Standard" instead of "Black and White".
Feb 01, 2011 | Fuji FinePix S7000 Digital Camera
My fujifilm camera has a problem when i take pictures in bright conditions the picture taken becomes pinkish whats the possible problem?
Wrong white balance setting maybe? Manual white balance only works in P, S, A and M setting, so switching the camera to Auto should solve the problem. If pictures are pink in Auto as well, the problem could be electronic.
Oct 20, 2010 | Fuji FinePix S7000 Digital Camera
My EOS 400D takes blue hued pics
You may have the white balance set incorrectly. If so, set it to "auto white balance".
Sep 25, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Unsteady White balance
You must switch to preset, push the awb button on the front to switch from auto white balance indoor to auto white balance sunlight (3200k to 5600k). This will automatically balance the camera to the approximate settings needed. For fine tuning the white balance.....
If you want to set the A and B buttons, first switch to A, then hit the Auto button by the user 1,2 3 button until you are off of auto total white auto focus auto iris mode AWB A ch will show in the viewer hit the Auto again and ATW shows, meaning Auto total white is on, and you will not have control over the white balance, it will continue to float and try to automatically balance in the middle of your footage. Once you are on AWB A ch from hitting the AUTO button, then point the camera at the white you are balancing to (of course put the white under the lighting you want to balance to) push the AWB button on the front of the camera and hold it in until the camera goes through the white balance mode and the black balance mode,...the camera will go dark while this is being done but an OK with the correct color temperature will show briefly on the screen when it is done and you can release the AWB button. Now you have set the A button to the white balance for the current lighting.
If you are going to be switching between indoor and outdoor, do the same for the B button above and set it's white balance to the exterior light color temp. that way you can just switch between A and B when you are moving fast between interior and exterior shots and have the correct color temp.
You could always leave the switch on preset, and hit the AWB button on the front to switch from 3200 to 5600, but remember not all light is either 3200 or 5600, that is why we use the A and B settings and get the White balance for the exact color temp of the space being shot in.
Jul 25, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Fujipix S5000 screen is all white
I just started having the same problem with my S5000, also.
Jul 11, 2009 | Fuji FinePix S5700 Digital Camera
CCD Nightmare time?
http://www.fixya.com/problems-solutions/t114852,p223253/Fuji-Digital-Cameras.aspx
Jul 23, 2006 | Fuji FinePix S7000 Digital Camera
Balance Function
This function is useful when you need more precise white balance than the Preset White Balance can provide. To set the optimum white balance for the shooting conditions, point the camera at a white object under the light source that you want to use, and press the OK button to set the white balance.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Fuji FinePix S7000 Digital Camera Logo
88 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
