Question about Crock Pots & Slow Cookers
I bought Tefal 4 in 1 slow cooker last week and couple of first times it worked OK. Now when I set hours for slow cooking it brings the food to boil in about 6 minutes and then switched to keep warm mode. :(
    President:
  • 3,433 Answers
I suspect that is the norm for slow cooking. The cooking temp is brought up and just maintained for the given time. Nothing wrong so :) . You wouldn't want the food to sit in liquid that slow in heating up. It's kinda like bbq'ing. You set the patio on fire and wait till the flames to subside before you put the hot dogs on. I think you are safe. :) - Ned I consulted with a crock pot fanatic, My Wife!
Posted on Sep 04, 2009
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Stew was supposed to cook for one hour. Not close to done. Still on but no idea how long it will take. Was set to slow cook as recipe said.
When you use a slow cooker, you must either boil the food before adding it to the slow cooker or add an hour to the cooking time to bring it up to a simmer. That is the time that the cooking actually starts to make the meat tender. Stewing beef would take at least 2.5 to 3 hours. The only way you would do it in an hour is you used fillet steak.
Feb 07, 2016 | Crock Pots & Slow Cookers
I have never had a slow cooker in my life and found this one in a garage sale without the manual. How does it work?
Yes you can use any cheaper cuts of meat or chicken and yes less liquid is used in slow cookers. add hard veges n use green veges for end of cooking time. cook for 6 or 8 hrs on low. Yeilds ecellent results. Find slow cooker books for great meals n desserts. I use mine every week.
Apr 22, 2015 | Crock Pots & Slow Cookers
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    I do NOT know how to use i.e keep at pressure without burning stuff. This is my daughter's Sambonet pressure cooker, it has a strange looking style of lid lock down that is part of the pressurisation...
    Pressure cookers rely on pressure and steam,
    Do a dry run first...well not dry but with just water, (no food) especially if it's an old cooker.
    Inspect for cracks or pinholes before you go ahead, a crack ANYWHERE in a pressure cooker makes it a bomb...or a flower pot.
    Ensure all safety devices like the pressure regulator and blow out plug are in good condition and not plugged.
    If some previous owner replaced the blow out plug with a bolt or something silly don't use the cooker till it's repaired.
    Bring your pressure cooker slowly up to pressure over medium heat with an inch or two of water in the bottom.
    When it starts to vent steam turn the heat down so the steam barely escapes, if it has a rocker weight it will wobble a couple times a minute.
    Slow gentle heat is the trick. A cooker will run for hours like that without boiling dry.
    A couple tips, use salt and spice sparingly, it's trapped in there and permeates the food.
    Be careful with foods that expand on cooking like rice and dried things, they can get up and block the vents if they reach the lid.
    TickMagnet
    Jul 22, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
    How do I start the cooker on low?
    The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
    The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
    If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
    To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
    If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
    Dec 18, 2009 | CorningWare SC60 Slow Cooker
    Royal doulton multi cooker
    not a solution as such but u can use it as a slow cooker on low
    put it on put veg in add water then meat leave about 1 inch gap from lid and put on low for a few hours dont let it boil dry
    Oct 15, 2008 | Crock Pots & Slow Cookers
    What is the function of both the Auto and the High setting on the cooker?
    I am not sure if it is the same as the Durabrand model I have but mine heats the food to boiling and then cooks and lowers the temperature automatically, it is handy if you are late preparing a meal, for example 12 noon and you want it ready for 7pm? Hope this helps. High settings usually boil quickly and is handy to use for the first hour after that reduce the temperature and you can knock at least an hour off the cooking time. Or you can use high throughout the meal and halve the slow cooking time, however this uses much more electricity than on slow.
    Jan 22, 2008 | Michael Graves Slow Cooker (4 qt.)
    To add water or not to add water????
    Slow cookers do not need water in the base unit to cook the food in the ceramic insert. The ceramic insert gets hot from the base and cooks the food. Here is a good guide to cooking with a slow cooker. enjoy
    http://busycooks.about.com/library/print02/ncrockpot101.htm
    Dec 06, 2007 | Select Brands SC-25 2.5-Quart
    Cooks too hot/fast
    Hi Wendigo,
    Crock pots are not exact, they only have a "target" minimum temperature (to be sure they kill bacteria). It's possible you just have a relatively strong heating element.
    Also, remember that the boiling point of liquids changes considerably with your altitude, so if you're in a mountainous region you may be seeing "boiling" at a lower temperature than you expect.
    Nov 12, 2007 | Rival 3040-VG 4-Quart
    Crock Pots & Slow Cookers Logo
    228 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
