Question about Garmin StreetPilot 2720 GPS Receiver
Clock doesn't update
Hi, recently my StreetPilot 2720 started losing track of time when off, meaning if I don't use it for a week, when I turn it on it will still think it is the moment it was last turned off. If a week has gone by, it can take upwards of 10 minutes for the thing to lock onto a satellite connection at which point it updates its clock. It used to pick up a connection within a few moments.
I guess there must be some kind of battery inside that powers the clock when the unit isn't in use, but I can't find anything that indicates this is so. Anyone has a similar problem? How did you solve it?
-- Jason
Ensure you have the latest software....7.10
Also, hold down the menu and map button when you power it up for 15 seconds or so.
Make sure you have a clear view of the sky....let it sit for 20 min.
Answer the questions on the screen and try again.
Note: doing the above will cause the unit to lose all your favorites, recent finds etc., so do a back up.
Posted on Dec 13, 2007
Trying to update but my computer does not recognize the device or port
Same issue on Mac OSX 10.4.1 with my SP 2720. Just purchased and is in excellent condition, never registered. Double checked all connections, downloaded and re-downloaded updater. Updater continues to say cannot find device. Tried other USB cables, ports, turned on/off, etc... Nothing. Would LOVE to know what resolutions others have found. Please let us know!
Jun 19, 2010 | Garmin StreetPilot 2720 GPS Receiver
Can't aquire satellites
If it is a streetpilot 2720 also may work on other models...
Turn unit off hold down menu button while turning unit on and, hold button down till a white page comes up that says general.
This this the testing mode if it is not testing then press the menu button, after test is down press menu button a couple of times and it will go to another testing, continue to the end turn power off then back on and should work it did for me.
May 28, 2010 | Garmin StreetPilot 2720 GPS Receiver
Streetpilot 2720 - also no audio
Yes send a message to the support address at Garmin for help I think the fix was removed as it had some incorrect steps
Jul 30, 2009 | Bennett Marine BENNETT DVD GARMIN...
How does one update th gps?
You connect the 2720 to your pc with the supplied usb cable.
Power up the 2720 with the ac supply cable.
Then run the garmin webupdater. It will do the update.
You must have previously installed the webupdater and the usb drivers. If you use the garmin mapsource software and can connect to the 2720, to transfer waypoints, tracks, etc., then the usb drivers are already installed.
You can download the webupdater at this site:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Hope this helps.
Feb 24, 2009 | Garmin StreetPilot 2720 GPS Receiver
Hard reset
I was told that you turn off the unit, hold down the FIND key and turn it on while holding. Keep pressed for about 10sec. then release.
Jul 25, 2008 | Garmin StreetPilot 2720 GPS Receiver
System missing
Well, for the 2730 which is basically the same, you turn off the unit, hold down the FIND key and turn it on. Hold for about 5 seconds and release. It should reset the unit.
Unlock Code
When updating the maps, you need to be registered with Garmin. All the numbers came with the unit. If you turn over your Garmin 2720, there will be a number flanked by "*". That is your unit ID. When you register, you must provide that ID. From the site, you can update your maps and you shouldn't need the 25digit key. It's programmed into your unit.
Jul 01, 2008 | Garmin StreetPilot 2720 GPS Receiver
No voice prompt
THere is a volume wheel in car speaker plug.
Dec 18, 2007 | Garmin StreetPilot 2720 GPS Receiver
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
Gps 2720
I tried another power cord and that was not the problem. I did do a firmwre update and that corrected the unit. It has been working well for the past 3 weeks. You should go to the Garmin website and download the latest FIRMWARE update.
Oct 02, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
65 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
