Question about RCA Scenium HD65W20 65" Rear Projection Television
Won't turn on - except for one cooling fan
My 65" Scenium was purchased for about $3000 in 2002 and worked great for a while. But, within 2 years it blew a capacitor (thank God it was still under warranty). Then in OCT of 2007 it's picture froze on the screen one night. No response from the remote control or switches on front control panel. Had to unplug it, but then it wouldn't turn on at all (except I could hear 1 of the cooling fans power up. I let it sit for a couple days still plugged in. Then for some reason I decided to press the power on button and it came on! Worked fine for 2 weeks. Then it died again. It has not recovered this time and it's been a month. Still have one fan that turns on. Two different repair men have looked at it and say it needs to checked out at their shop with more sophisticated equipment. I have been told that the DirectTV box is a big problem with these sets and you may not be able to acquire the part(s) to fix it, or the part costs around $800. Not worth it. Can't believe an expensive set like this only lasts 5 years. RCA / Thomson is not a brand I will be doing business with in the future.
  • KenHD65W20 Mar 03, 2008
    Jim4157 ... Did you ever sort out how to fix your TV? My TV just powered off, and now it won't power back on. Went into the back to look for a fuse. I found one up top near the projectors that tested OK. Is there one associated with power?
  • nmucat97 Oct 19, 2008
    Mine did the same thing, the repairman said it needed a diode part # 248997 and it would take about two weeks to get...here I am at 3 months later and apparantly you cant get that part anymore.... you would think at least 1 place would have a diode that is about a two dollar part.
Thee is a fuse near the power plug-in it's a 6amp 125 v ....make sure you bring the fuse with you..will solve the off problem
Posted on Dec 23, 2010
2 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: thomson scenium
If you changed all 3 CRT's at the same time you are in for alot of alignment. If all 3 need to be replaced then 2 should be replaced then aligned to the remaing original then replace the last after all alignment is done. You will probably need some kind of template provided by RCA to do alignment especially if the set has auto convergence. Good luck....
Posted on Jan 11, 2008
Cooling fans not working properly
And why do you think this is a problem, they do not run anymore than what is required to cool the engine, as it gets hotter the fans will run longer at a higher speed, but you will seldom see that except on very hot days.
May 15, 2014 | 2001 Pontiac Aztek
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
Nov 08, 2017 | Cars & Trucks
I have a Hotpoint Mac 161 air conditioner. We've had it for one year. Now it won't blow air out the front, on any setting. On fan only, nothing happens at all. On cool, the air blows out the exhaust. Whats...
Yeah i had the exact same problem except yesterday it all of a sudden went 'pop' with an orange flash inside it followed by shorting out the electricity in my place. I suggest not leaving it alone while it is operating like that.
I range up Hotpoint today and they were more than happy to replace it. Infact, they just took the unit (and left everything else here, including the remote, etc) and gave me a new mac 161 (with all the new stuff) within 2 hours of ringing! Their service was great.
Nov 13, 2010 | Heating & Cooling
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Picture freezes and turns its self off and then turns back on
this happened to me with my RCA Sceium 52 inch floor model, for 2 years before I figured out it was
over heating. Of course I had no money to fix problem. What I did is simply put a cool fan on back
or AC. Even rolling in front of a sliding glass door when its cool out will work well. Cold air on back
will stop it from turning off.
Good luck
Apr 26, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Boggs down after 2-3 minutes.
Yeah after boot up the cooling fan should kick in. If it does not and it is a laptop it will get too hot in there. Thermal Shutdown protection will kick in, if it is equip. If in 2-3 minutes it got so hot reaching its preset temperature shutdown, it will be down to prevent damage to the system.
Apr 13, 2009 | Toshiba Satellite A45-S121 Notebook
Rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Mark
Nov 08, 2008 | RCA D61W130 61" Rear Projection Television
I have 2 cental a/c units in my home. The 2 1/2 ton unit cooled great until abut a week ago. Now I cannot get it too cool lower than 78-79 degrees and it runs constantly unless I turn the themostat...
i like this one it challenging first do you know the refrigerant pressure?should be at least 65 psi for r-22 has any thing changed in the ducting? is the fan turning the correct direction?dan
Jul 14, 2008 | Heating & Cooling
RCA Scenium HD65W20 65" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
