Sony VAIO VGN-FS640W PC Notebook
Problem for Sony VAIO VGN-FS640W PC Notebook
Headphone jack seemingly screwed up
By tommy81 on Sep 04, 2009
I have a Sony Vaio VGN-N365E. When I plug headphones in usually I can only hear audio on the right side. When I press down on the plug that's in the jack, the left side works and it sounds normal. When I release the downward pressure it goes back to only the right side again. I thought it might be the headphones causing the problem, but it's not. I tested another pair and the same thing happens. It's seems to be some kind of hardware problem. Does anyone know what kind of parts may be the culprit? The headphone jack, microphone jack, and usb connectors seem to be all attached to the same thing because they all move when pushed. Would this be something that I would need a professional to work on or could someone with little to no computer repair experience do the job? This thing is frustrating. Thanks
Solution #1
posted on Sep 04, 2009
Not Rated)
drtw76
Rank: Wiz
Rating: 87%, 13 votes
What generally happens to connectors, especially exposed to air is they oxydize.
Buy a can of "Contact Cleaner" from a local Radio Shack and spray it (through the thin tube usually provided) into the jack. One quick push, dont flood it. Take the earphone jack and insert and remove it several times, wiping off excess, which sould clear contacts and it should work normally again. If not it would have to be replaced which is no easy matter requiring an experienced Technician or Factory. Sometimes it cannot be replaced without damaging the Mother Board. This however sounds like a common problem the Contact Cleaner will fox
Cheers,
Good Luck :)
Was this helpful?
Yes
No
Popular Solutions for Sony VAIO VGN-FS640W PC
Questions and Unsolved Problems for Sony VAIO VGN-FS640W PC
Do you recommend Sony VAIO VGN-FS640W PC Notebook?
Answer
Answer
my compaq notebook 6510b wont come on When I start the laptop the power and cd light... is this... (More)
Answer
how do I use webcam MSI EX625 notebook
Answer
how to get bluetooth on emachine e627
Answer
I think my alt car button is on right now because all of my apostraphes and parentheses and such are... (More)
Answer
laptop sudden power shut down about 2 min after been turned on and won't turn back up
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
