Question about Daewoo Washing Machines
Daewoo 1210s what does error code h6 mean ?
Machine stops in middle of program and code h6 is showing on the digital display
Master_Tech
  • 770 Answers
SOURCE: 5L error code
I will pull the book and get back to you today
Posted on Jan 27, 2008
Coldcut
  • 1554 Answers
SOURCE: error codes
If this machine is like other of its type then you may find the manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
Posted on Jan 29, 2008
SOURCE: error codes
My Kenmore H3 stops working, starts beeping and flashing "F9", but it only happens when I'm washing a heavy load like jeans or bath towels. I think it gets off-balance and I have found that if I hit "pause" once and then hold in "start" briefly it somehow resets itself and works fine from then on till the load is completely done.
Posted on Feb 22, 2008
s4u311
  • 813 Answers
SOURCE: error code h6
hi friend
hi think ur proggremed chip has been damged so u have to chage it or a timer ckt has a probelm so chenge it
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: Error code SD
I work for an appliance company in the service department, and what this really means is that you could have a suds build up in your machine, or that you used too much soap on this particular cycle. If starting over does not work, you can buy a product called washer magic at almost any store and it will clean your machine out. Also, running vinegar through the machine will make any suds dissapate.
Posted on Sep 05, 2008
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
Error code h6
hi friend
Apr 05, 2008 | Daewoo DW500M Top Load Washer
Tenho uma maquina daewoo modelo f1042sp e no meio da lavagen da me h6 ajudeme
I have a machine Daewoo model f1042sp and in the middle of the washes me h6 Help me
http://gethuman.com/phone-number/Daewoo-Electronics
877-393-7823
Press 1, then 2.
Average Wait: 9 mins - Mon-Fri: 9am-8pm EST
Apr 04, 2015 | Daewoo Washing Machines
Fault code h6
Hi my washing machine ( a swan sw3010b ) keep draining the water and after a while it shows a foult IE. Can someone helps please
Nov 14, 2011 | Washing Machines
Videocon Split AC, Model VBS53 showing H6 Error. Please Help
h6 problem create a machine showing a display?
Jul 01, 2011 | Heating & Cooling
Washing machine error code h6
hi,
seems a spade connector had dislodged itself from the back of the machine reattached and all works seems it was a heat problem.
Hope this helps
please give me a FixYa rating if the solution works.
Thanks
Jan 04, 2009 | Washing Machines
H6-00 IS SHOWING UP
Dear sir; H6-00error code on this machine , it means "fuser oil empty" you just add the fuser oil in it should be OK, if still have problem please let me know, otherwise be generouse give a rating.
Dec 22, 2008 | Sharp AR-C160 Color Copier
DWD1210S/1210W
H6 is an error code with the heater - you will need to get a professional to look at it.
We have one of the machines and it has been trouble since day one. We will not be getting another.
Aug 17, 2008 | Washing Machines
Washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Nov 09, 2007 | Washing Machines
Washing Machines Logo
668 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
