Question about IBM Infoprint 1332 Laser Printer
Maintenance error 80
In the display of the printer I have the ignition "Maintenance 80" the printer dosn't print
  • 1 more comment
  • Anonymous Jan 10, 2008
  • jisherwood Dec 02, 2008
    I am having the same problem but only want to know how to reset the maintenance count.
  • leahg Feb 09, 2009
    How do I reset the Maintenance Count on the Infoprint 1332?
Put a maintenance kit in the printer and then reset the maintenance count.
Posted on Mar 12, 2008
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
On my Brother MFC410CN Printer Message reads Unable to clean I have followed TroubleShooting instrctions and it still appears
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the Menu/Set, Black Start, Menu/Set, and Black Start keys in this order.TIP: For the FAX models equipped with numerical keypads, you may press the Menu/Set, Black Start, and 0 keys instead in the same way as conventional models.Then "MAINTENANCE 10" appears on the LCD. Press 82 using the numerical keys/arrows.
Then press the Menu/Set key.
Error code will display indicating source of error if it is 41 thats print head error,
replace machine.
press stop to exit if needed.
(http://www.fixya.com/support/t250171-brother_mfc_215c_unable_clean)
Oct 06, 2008 | Televison & Video
Getting a 80 Maint. Error. Replaced the fuser. How do I reset the paper count?
Go to Config by turning off the printer. Then press and hold Select and Return buttons while turning on the printer. Once in Config Menu, choose Reset Maintenance Count.
NOTE: The error indicates that the printer has already printed 300k pages, worn out transfer and charge rollers. You should've replaced the maintenance kit = fuser, charge roll, transfer roll and pick tires. Otherwise, you'll ge having print quality issues.
Jun 15, 2010 | Lexmark W840 Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Getting error message CLEAN UNABLE 46
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
Mar 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Error 80-maintenance
The operator panel displays this message at each
300K page count interval. It is necessary to replace
the fuser assembly, transfer roller, charge roll, and pick
rolls at this interval to maintain the print quality and
reliability of the printer. The parts are available as a
maintenance kit.
Description Part number
Infoprint 1332/1352 Infoprint 1372
115 V Maintenance kit 56P1409 56P1855
220 V Maintenance kit 56P1412 56P1856
100 V Maintenance kit 56P1413 56P1857
I have new Maintenance Kits in stock at this time. You have the option of doing the kit on exchange or outright. Your Part # should be 56p1409 if you are in the US.
Please give me a call for pricing of if you have any other questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
AOL IM: RORYMRP
rcardenas@mrp.to
Jul 07, 2009 | IBM Infoprint 1352 Laser Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Printer want print
OK Try this
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
IBM Infoprint 1332 Laser Printer Logo
1,111 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
