Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Diswasher not working
The "Clean Light" indicator keeps flashing and does not turn on. Is there a reset switch that I should try?
  • 1 more comment
  • dialtone37 Dec 12, 2007
    I have the same problem. Clean light flashing 7 times... My model number is 1603-3401...I pressed "heated dry...hi temp wash...heated dry....high temp wash, did this 5 times, lights flashed and it was ready. Before I did the key button dance, I verified nothing was plugged up and the bottom was clean...
  • Anonymous Mar 29, 2008
    GE Dishwasher QLD5860L:  Close and lock the door - beep sound - light on - doesn't respond to the start button.
  • dad303 Apr 25, 2008
    i have same problem. local repairman says control board needs replacing. cost is 180.00 for part and 55.00 labor. unit less than two years old.havent decided if i will fix or not.
  • 18 Answers
If you have a Kitchenaid. You need to press in this order.... high temp, energy saver dry, high temp, energy saver dry, the lights will all start blinking, after they are done the cycle will start. Press cancel twice. ;)
Posted on May 10, 2008
I have a problem with dishwasher and model is KUDSo1DJSS0 when i try to turn on , no action at all what should i do
Posted on Dec 24, 2008
    President:
  • 878 Answers
Hoffy, if this is a Kenmore or Whirlpool, do the following key-dance, high temp wash, heated dry, high temp wash, heated dry. If you don't have heated dry, then air dry. This will reset the board. All the lights will light up and go through a diag test mode. You can advance it through by pressing the start button. Now don't go giving this a crappy rating if this is not a Kenmore or WP, as you didn't post a model number for me to scope it out. Catriver.
Posted on Dec 07, 2007
Why does indicator light keep flashing,switch in nutral 1976 mini moke
Sounds like you need to replace the indicator stalk, first remove it, clean it up with wd40 clean electric connections & see if it works
Mar 07, 2015 | Mini Cars & Trucks
Ford Focus CL 2003, Door open light keeps flashing, indicators either trip out or go double speed when door open light on.
At the door jam,check the condition of the pin switch. The switch may be cover with a boot.
Compare the condition of this pin switch to the working side.
Clean the general area and re-test.
Jan 19, 2014 | Ford Cars & Trucks
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
Clean light keeps flashing, cant get it to reset. What can I do?
Hi, if the clean light flashes it is indicating the was no rise in water temperature during the water heating cycle. This link below will explain things that could cause it and tell you how to reset the control so you can wash for now. Let me know if you have questions.
Be sure to follow the 'key dance' just as specified'
Thanks!
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 02, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Stainless Steel- LitchenAid diswasher will not star
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Diswasher malfunction - won't start clean light flashes 7 times The clean light keeps flashing green. Can't get the washer to start. The only operation it will do, is drain when the cancel / Drain button...
This information may help in your situation. This can be a common problem on some Whirlpool manufactured dishwashers. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 10, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
658 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
