Question about Samsung Blast Cellular Phone
The white screen of doom as i call it..
I have had this phone for over a year so it may just be the age but i have had a few instinses when the screen went white when i slid it either open or closed. it usually only lasted once and i just turned it off and back on and it was fine. only had happened a few times until today. now every single time i slide it no matter which way it gets the white screen of doom and wont fix itself. i have to turn it off and slide it how i want it then tunr it back on. its very irritating. help? plus my camera doesnt work anymore. it was fine but then it started saying capture error and then finally the lens or whatever went all contrasty and like green and purpley colored. now the whole think is bright pink. cant even see anything through it.
Hi! My toshiba 2100td tv is over 10 years old and last few years it's having weird problems. When it's turned completely off (not in standby) and when I turn it on, the screen blinks for a 10-
The real problem here is its age, a lot of these sets of that age critically needed parts are just no longer available.
I repair them but the real risk is someone fixed it, a few months later it develops another problem etc etc etc.
Ten years is now a days a long life for a TV.
Apr 16, 2012 | Televison & Video
Screen suddenly turn white and done all that i could like hard reset but when i switch it on again, it was normal only for a few seconds before turning to white screen again...
If you you are experiencing white screen and nothing changes even after doing a hard reset you may want to call or contact HTC support. Be sure that it is still cover by their one year warranty. Coz having a white screen might caused of a lot of things like infected by virus, water incident, mobile phones has a physical damage. Check as well the lcd of the phone. try to get in touch with them with the link below.
http://www.htc.com/sea/CA_Hotline.aspx?region=NorthAmerica
Mar 16, 2011 | HTC Touch P3450 Smartphone
I have a samsung HLS4266WX/XAA about 3 years old with white dots.
This is a known issue with Samsung DLP sets. Here's a link to the solution:
http://forums.cnet.com/5208-13973_102-0.html?messageID=3162774&tag=emfrnd#3162774
Jan 01, 2010 | Samsung DLP HL-P5663W 56" TV
White screen of doom.
If your screen is completly white then unfortuanetly the screen itself will be at fault & would need to be replaced. On some LCD models there is a small fuse on the drive board attached to the screen, again on certain models this can be accessed & replaced but there is no guarentee that this is the only problem.
Aug 17, 2009 | Televison & Video
My Motorola W385 from MetroPCS has a White Screen
It should be dry "after few years", Probably is time to get a new phone.
Mar 27, 2009 | Motorola Mobility W385 Cellular Phone
White Screen of Death?
Its you phone. you have to go to service center and ask to replace its fle or ribbon wire. 100% tested.. Thank you
Nov 13, 2008 | Samsung SCH-a870 Cellular Phone
My Zen plays music but has a blank screen?
This is what you call the WSOD or the White Screen Of Doom. Is it still under warranty? If yes, go and have it returned or RMAd. Or you can try to download the Recovery Tool found here
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?
Oct 19, 2008 | Creative Labs Zen Digital Media Player
White Screen of Doom
have you tried unscrewing the back, the removing the battery. one thing that i did was i held the button down, it seems like it is not restarting, but if you hold it down for atleast 2 min, then it will actually restart, otherwise remove the battery, its just like a cell phone battery, just pluck it out
Jun 21, 2008 | SanDisk Sansa e260 MP3 Player
White screen
Any answers to this,... I have had mine for 3 weeks and now can't use it!!! Due to the white screen HELP!!
Jun 15, 2008 | Nokia e65 Cellular Phone
Motorola razr v3 won't charge
have you tried measuring the output voltage on the charger?? if not... use a multimeter to check if there is a voltage coming out on the charger.. if there is... you doomed.... the charging module (charging IC) on your phone is fckd..
Jan 11, 2008 | Motorola Mobility RAZR V3
Samsung Blast Cellular Phone Logo
219 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
