Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
The compressor comes on and goes off does not cool refrig very well
    Sergeant:
    Champion:
  • 205 Answers
Hello sir/mam
if your refrigerator is having cooling problem then the problem is in the compressor check the refrigrant if this is low compressor wont cools so please call a compressor tech he will help you.
Posted on Sep 04, 2009
    Problem Solver:
  • 5 Answers
If it has a removable greet in the front bottom,remove it and vacumm off the condenser coil, works 9out of 10
  • 159 Answers
Change the thermostert heater
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
I have a hss25ifmdww thats not cooling the compressor is not coming on how can i check to see if its a bad control board or compressor
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire1 , and the other into wire3 . Plug the refrig back in and see if the compressor now runs . If it does , replace the board . If not , compressor is bad . When testing , ONLY the compressor will run and nothing else will .
Jan 17, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My frost free fridge freezer comes on for five minutes every half hour and is not cooling very well, what's the reason for this?
1 Check the thermostat settings i.e. temperature control. Hope it is not on the lower number. 2 If the thermostat setting is OK then there is every possibility that the cooling gas has leaked out. Call the technician and get it recharged. 3 Also check the compressor that it is working properly.
Jul 31, 2010 | Refrigerators
Kenmore 795 refrig is not cooling sounds like everything is running but no cooling. took back panel off and hear a click then a electrical sound which goes for under a minute then shuts off
That indicates that the compressor is overloading the wiring. That clicking noise is the thermal breaker. The freon could be low. causing the compressor to overheat, or the compressor itself is deffective.
Nov 25, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrig/Freezer not cooling
"compressor not functioning". You Probably need a New Compressor. I have a Family Member whos Refrig/Freezer Compressor had to be replaced under Warranty when it was only 2 years Old.
May 12, 2009 | Refrigerators
Cleaned coils,lower fan, drain lines. Checked door seals, temperature reset, both fans are runnign but
Need a New Compressor. That is the only way of Cooling. If it was working and not cooling it could be the Condensor or low on Freon.
Hot fridge seal
sounds like its overheating badly, check the condensor coil under refrig asuume its toatll clogged also check the condensor fan motor located behind refrig next to the compressor, its supposed to blow away the heat and keep things cool under there if its not spinnig youll need to replace that as well
Mar 14, 2008 | Refrigerators
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
128 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
