Question about Craftsman 10" Table Saw
My 10 inch table saw is over heating without a load on and i have a heavy cord
    Sergeant:
    Champion:
  • 205 Answers
Sir please check the bearings of the motor and if its not good should be replaced.
Posted on Sep 04, 2009
Ryobi 10 inch table saw trips breaker when he turns onRyobi 10 inch table saw trips breaker when you can it on
First of all the saw needs to be plugged in directly to a outlet . NO Extension CORD !!! If it is Right , then Check on the motor label and see how many AMPS the motor is ? You need to then check the Breaker box and make sure the breaker is big enough to handle the load of the motor on the saw . You may have to make sure that the saw is the only thing on that breaker . NO Refrigerator , A/C , ECT.
Also make sure that the motor is clean and not packed full of saw dust . This can over heat the motor and kick off circuit breaker fast .
Good Luck , Hope This Helps !!!!!!!!!!!!!!
Aug 22, 2014 | Saws
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
D24000 wet tile saw smells of burning. What could this be?
mmm.. motor problem,armature or field coil burned or bearing burn motor housing
Jun 03, 2012 | Dewalt D24000S Heavy-Duty 10-inch Wet Tile...
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
Saw reset button keeps kicking after only a few minutes of use. Could the dust collection bag be creating a heat problem?
I would not think so, the reset is for thermal protection and I think that you have a problem with the motor stalling or under a heavy load. I would check to see how free the motor spins with being on. UNPLUG TOOL FIRST and turn blade by hand. Then to eliminate the dust bag remove it and just run the saw without cutting. Look into the throat plate area for a build up of debris that might be limiting movement.
Jul 23, 2011 | Craftsman 10" Table Saw
Table saw overheats triping braber. have cleaned contacts and tighten the conections on the side of the saw.
Usually a saw that size will have it's own breaker built in, is this the one that is tripping? Or is it the one on the wall? Either way, a dull blade will make the saw work harder, and heat up faster, Mine trips off now and then, always from a dull blade. It has a built in breaker in the switch. Are you running it with a cord? Make sure it is heavy enough, a small cord will steal amperage from the circuit turning a 20 amp breaker into a 15. Hope this helps.
May 28, 2011 | Hitachi C10FL 10" Stationary Table Saw...
Trying to cut any size piece of wood the saw blows the circuit breaker at the panel 1x4 piece
Are you operating the saw on a 10 amp circuit or with a long extension cord? Table saws need at least a 15 amp circuit and should not be used with an extension cord. If absolutely necessary the extension cord should be no less than 12 guage. Tabel saws will run OK on a 10 amp circuit but as soon as you apply a load (try to cut wood) the power requirements go up to keep the saw turning. If you can, plug it into another outlet on a higher capacity circuit breaker or at least closer to the breaker box. If it still pops the breaker you may have bearing problems in the motor that are creating too much friction. This would make the motor work harder to turn so it would draw excessive power and trip the breaker.
Apr 13, 2011 | Craftsman 10" Table Saw
The belt on my 10"
you need to check your brushes again. something is making contact or shorting out. look at everything carefully
Dec 25, 2010 | Delta 36 979 10 Inch Left Tilt 1 1/2...
I would like to down load a manual for a skil 3400 15 amp 10-inch table saw
Try the link below
http://dl.owneriq.net/5/510469e6-b93a-4517-93a8-a670a7ce5782.pdf
Dec 03, 2010 | Skil 10" Table Saw 3400
Power problem
The problem is not the saw but the power supply... make sure you are running the shortest extension cord possible with a heavy gauge cord into an outlet that has its own breaker.
Jun 20, 2010 | Skil 10" Table Saw
Craftsman 10" Table Saw Logo
66 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
