Question about Mitsubishi VS-50605 50" Rear Projection Television
Green lamp/bulb I recently purchased this television and had problems with the green color. I took off the black panel and noticed the green lamp is flickering.Any ideas?
  • austins Dec 15, 2007
    Now the red did the same...held in the buttons and showed one light,pause,2 lights, pause,one light,etc....
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence
Posted on Dec 07, 2007
Have a mitsub. WD-73734 working fine this morning with white and black dots - replaced the chip and now the tv won't turn on, green light blinks raptly then the lamp light starts to blinks red/orange
Somehow--the lamp is not firing. Before you go get another bulb--check ALL of your work, and make SURE no connectors to the ballast have been left off or pinched somehow. It is easy to do this. Also, make sure the lamp door switch is making proper contact with the tab on the lamp door. You have already fixed a real problem with this set--do NOT give up so easily now!! ALso--make sure all fans are running. If ANY do not run--it WILL shut down. ANd make sure the color wheel connector has not come loose or been damaged somehow (this will be between the engine and the lamp area--likely have a "hump " raised in the light tunnel betwen the lamp and the engine--this is where the CW is). Even IF the ballast died (NOT likely at all), you can find one on ebay for under 100---and this set IS WORTH the repair. You will NOT be satisfied with some crappy flat-panel as a replacement.
May 08, 2014 | Mitsubishi WD-73734 73" Television
No picture
the projectotr circle is the colorwheel and it has to be replaced. as far as having no picture, is the led on top flashing red or green ? If flashing red how many times ?
Jun 12, 2010 | InFocus ScreenPlay 4805 Multimedia...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Lamp works, but it says to replace it.
You are not going to believe this one. My TV had the solid red light took it out inspected the bulb noticed on top where the the wire feeds through there was a black mark I carefully wiped the black off cleaned my filter stuck the bulb back in and its working like new again. Color is brighter than ever. Also left TV unplugged for 1/2 not sure how long it will last but will enjoy as long as it works. Others might want to give this a try before spending hundres of dollars that may not be necessary.
Dec 19, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Sharp TV Flashing Codes
did you purchase just a new bulb? or did you buy the bulb with the cage included?
Oct 21, 2008 | Sharp 56DR650 Television
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Color Lamp
It is not as simple to replace as a bulb. This is a picture tube, and for a novice, no play it safe and have a tech have a look first. Just because the picture tube does not light up, does not mean the tube is bad. There could be several things in the solid state circuits that could cause this problem. Good Luck
Sep 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi VS-50605 50" Rear Projection Television Logo
32 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
