Question about Apache RC Mini Helicopter AH-64
I have an apache 3 channel helicopter.the top blades no longer spin so the helicopter just spins clockwise very quickly
  • Anonymous Mar 12, 2014
    bottom rotor spins on the helicopter but the top rotor doesn't need repair answer
  • Anonymous Mar 30, 2014
    when i turn on remote it makes a siren noise, and light stays red. nothing hapens!
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
Rotor spins while charging
You have a bad flight control board. There may be a loose wire near 5be charge port making fontact wi5h the output circuit for the main rotors. Good luck
Feb 26, 2014 | Generic Udi u13 3 channel co-axial...
My S107g worked great for a week but then the top blade just stopped moving. The lower blade is spinning away and the top one sits there limp. What's going on?
well firstly you still have warranty on it, get them to replace it..
the blades are controlled by a motor and a gear system in the helicopter itself. The gear is broken or the motor is wedged in by the gear. or simply burnt out, You will need to open it to unwedge the gear and if it spins when you turn the gear, you need to replace the motor. Both blades use separate motors that's what allows it to trim (turn) when one set spins faster than the other, It goes straight when both blades spin at the same speed.
Dec 29, 2012 | SYMA Toys industrial New Syma S107 Radio...
My helicopter wont come more than 6 inches off of the ground. What could be wrong? There is nothing tangled in it and the item is new.
sounds like remote control is out of adjustment. Instruction book if you have one shows how to null out the rotation i found that if not right to much rotation the main blades lose some power. When i adjusted it to cancel the rotation the copter lifted quickly. may be the problem. adjustment is on the lower rigfht of controler.
Dec 25, 2010 | Cobra Electronics Cobra RC 3 Channel Mini...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
I crashed my Apache onto a table and when I try to fly it, It keeps spinning out of control. To my knowledge I don't see anything broken. It spins to the right. Please help! thanks!!!
It sounds like your tail rotor is acting up or missing. It keeps your Helicopter from flying in circles.
http://www.start-flying.com/new%20site/heli1.htm
Oct 04, 2010 | Apache RC Mini Helicopter AH-64
Walkera lama 400 just spins round
The walkera Lama has a bad gear setup,there are two tiny screws on the top
gear which powers your bottom blades one on each side of the outer shaft
if these two screws were not properly tighened at the factory or you ran yourLama
400 into the ground even if it was at a slow rotation when the bottom impacts
the ground the bolts shear off the outer shaft and you no longer have 100%
power to those blades,if your helicopter spins clockwise and you tried every
thing,this is the problem,replacement is required or you can tear it all down
and drill and tap two new holes with new screws,these are machine screws
and are less than 4/40 which is very small.To check hold top gear with two
fingers left and right side of gear and turn the bottom blades only,if the blades
turn your shaft to gear screws are sheared off
good luck
SK Florida
Sep 12, 2010 | Walkera Toys
Yiboo AH-64 3D RC Mini Apache Helicopter, out of the box, charges, but will not do anything, channel C
Mine worked good for 3 days then died..Top blades wont spin.. It worked really well. The guy at (as seen on TV) shop that sold it to me actually seemed to tell me "Do not buy this!" But I bought it anyway at his word that I cannot bring it back no matter what after 24 hours..spent 90 bucks on this junk and there is NO SOLUTION
Oct 02, 2009 | RC Toys
Tremendous machine vibration
Make sure the "connect buckle" is connect to the correct side, and not bent in the middle, it should be straight. If this doesn't help, new blades are sometimes different weights try to matching the weight of opposing blades you may even need to sticky tape a small weight underneath the blade to get them balance. Don't stick anything on to the top of the blade.
May 25, 2009 | Apache 3 Channel Micro Indoor Helicopter...
Need blade for world tech skyhawk helicopter
Syma DragonFly 9093 or 9083 rc heli... has the same exact size tail blade... just put one on myself... works fine..
Dec 23, 2008 | Toys
Apache RC Mini Helicopter AH-64 Logo
1,075 people viewed this question
Top Apache Toys Experts
ray gallant
Are you an Apache Toy Expert? Answer questions, earn points and help others
