I need Windows XP on usb drive. Where can i find a sata driver for an HP DV72138SF
  • 22 Answers
On hp's website
Posted on Sep 04, 2009
Sata drives for windows xp
Go here and download Matrix Storage Manger for sata drives, you have to select your OS first >>>>>>
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
Once downloaded you have to make a floppy disk or a bootable USB drive so make sure you read all the information first before performing the data transfer to the floppy/USB.
Once your happy that the files are on the media and in the USB port or floppy set the XP install going and watch the screen for the F6 prompt, it will be at the bottom right hand side of the screen and you have to be quick to install the third party drivers.
Good luck.
Jun 28, 2009 | HP Compaq Presario V6700TX Notebook
Can not setup windows xp sp3 sata on hp compaq presario v6700
Ok, the problem here is that the Windows XP CD that you have does not have the proper SATA drivers on it already. There are two ways to get around this:
1. Locate the drivers for your SATA controller from HP's website. Copy them to a floppy disk (old 3.5" style) and install the drivers during the installation. When booting up the XP CD, one of the first things it says is "Press F6 to install 3rd party RAID or device drivers". This is where you would press F6. During the install, it would ask you to provide the hard drive controller drivers. Windows XP only allows for these drivers to be installed from a floppy disk, so if your computer doesn't already have a floppy drive, you'll need to get an external USB drive. Once you give XP setup the correct drivers, it can find the hard drive and continue with the installation.
2. Create a custom XP installation CD with the new drivers on it. On another computer with internet, CD-burning capability, and a lot of time and effort, you can slipstream the SATA drivers into the XP CD that you have now. This is not a process for novice users, and can be very time consuming. For a single installation, you're better off with the floppy drive option.
In order to find the correct SATA drivers for your computer, we'll need to know the exact make and model of your computer. The Presario v6700 is a series, there are many models inside of that series. They most likely use the same driver for SATA, but it'd be nice to know exactly which model you have. THis should be printed on the bottom of the laptop.
May 14, 2009 | HP Compaq Presario V6700TX Notebook
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
Blue screen
If  you are trying to install Windows XP in latest Notebook, it will not be able to detect the Hard Drive since all the latest Notebooks are shipped with SATA Hard Drives and by default and Windows XP will not be able to detect SATA Hard Drives by default.
If you are having a Intel based Notebook, you need to download the SATA Drivers from the link below :
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36132.exe
Find the instructions to create a bootable XP Disk using the SATA Drivers from the link below :
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
Hope this helps...
Mar 07, 2009 | HP Pavilion dv6000z Notebook
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
XP on HP Pavilion dv2000
yes
because it's using an AHCI  SATA driver
there 2 ways to install XP on your laptop
  1. If you own an external floppy disk. You can insert the driver before the installation begin. the setup will ask you to insert third party driver by pressing F6 at the first of installation. Press F6 then insert your SATA driver. choose it. then setup will detect your hdd. you can download the SATA driver form here:http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/HP-Pavilion-dv2054ea-SATA-Driver-550.shtml
  2. It's very hard to find an external floppy drive today, unless if you are an OEM or retailler. second way is you can insert the driver to XP installation CD, but it's very complicated. Or you can download a XP installation CD with sata driver here:http://fenopy.com/torrent/Windows_xp_sp3_5512_cdr_october_2008_with__sata_raid_/MTU2MTEzMA==/index.html
  1.
Jan 24, 2009 | HP Pavilion dv2000t Notebook
Motherboard drivers
I contacted HP the other day for a problem while trying to load XP on a VISTA box. They sent me to this site.. and gave me instructions for resoluation or at least an attempt.. Hope this helps
Thanks David
Let me know it if works for your problem
Solution: The reason for this error message is that notebook has been shipped with SATA hard drive i.e SATA hard drive controllers. But Windows XP does not have built in SATA controller drivers.
To solve this problem we need to install SATA Controller drivers before we install Windows XP using a USB floppy drive.
Many customers are not ready to buy USB floppy drive and installation of XP is so complicated using USB Floppy drive.
We have found the driver for the SATA controller on Intel Website. Customer has used it and installed retail Microsoft Windows XP with SP2 successfully on his dv6500 notebook.
The same can be achieved in all the dv2500, dv6500 and dv9500 also DV2600, DV6600 and dv9600 notebooks.
Here is the link for the SATA drivers:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&lc=en&softwareitem=ob-39535-1&jumpid=reg_R1002_USEN
1. The file contains the Intel Matrix Storage Manager Floppy Configuration Utility.
2. This utility will create a floppy disk containing the RAID driver files for installation on a 32-bit operating system.
3. This floppy can be used to pre-install the Intel Matrix Storage Manager driver during the F6 portion of Windows setup.
4. You needs Microsoft Windows XP with SP2 Operating System disc and the USB Floppy drive.
5. After downloading the SATA driver in another notebook, you needs to extract and execute the file. It will help in creating the floppy disk that has the SATA drivers.
6. Boot with the Microsoft Windows XP disc and make sure the USB floppy drive with floppy disc is connected to the notebook.
7. At the F6 prompt, select F6 to install additional drivers which are not in-built in the retail Microsoft Windows XP Operating System disc.
8. When the prompt comes up to install additional drivers, insert the floppy and select the correct SATA Driver. It is Intel 82801HEM/HBM SATA AHCI Controller.
9. Once that is done, the rest of the installation runs as normal. There are only 2 drivers in the floppy disc that would work.
10. After the Operating System is installed in this manner you can install the chipset drivers for the notebook.
11. However for the other device drivers once Microsoft Windows XP is installed you may not have them from HP as these series are not released with a Microsoft Windows XP Operating System. The drivers like audio, ethernet and media card reader drivers etc.
12. Please be sure with EU that he might not have the other drivers from HP after installing the retail Microsoft Windows XP.
Note: Do not click on the link. Copy and the paste the link into the address bar of the web browser.
If the above solution does not resolve the issue, please login to chat support with the results of the above troubleshooting steps. Also, please use the same email ID.
Dec 07, 2008 | Compaq Presario Notebook
Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option...
Hi.
I will explain you the issue.
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
http://www.scribd.com/doc/4864999/sata
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Sep 09, 2008 | Computers & Internet
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
