Question about Mitsubishi VS-50501 50" Rear Projection Television
My Mitsubishi VS50501A Rear Projection TV turns on then off!
When I push the power button, it turns on and then a second later it turns back off. I read some places that it's probably the fuse or something. But I can't find anywhere on the net that has what i'm looking for! Can somebody please tell me what kind of fuse I need (ratings)or if it might be something else.
THANKS IN ADVANCE!!
Hi name is Ernie, and i have a mitsubishi vs-50501a .... my problem is that the picture is out.. i got sound but no picture.. the problem started with the tv turning off after 15min. then i would turn it back on, 15min later it turned off again. So now it stays on but no picture.. let me know if i can fix it myself.. im mechanically incline.. thanks.
Posted on Oct 03, 2011
SOURCE:
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
I have a mitubishi 42 1080i tv projection. i turn it on & 2 seconds later it turns off help
Provide correct model number but TRY:
when it shuts off, on the front of the set push both the menu and input buttons at the same time and hold them for at least 5 seconds and release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks a pause and repeat it 4 more times.
Let me know error code and I will assist you.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 20, 2010 | Mitsubishi WS-65807 65" Rear Projection...
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Turn on the tv a few seconds later it shuts the power light blink
Replace both of your convergence ICs they are STKs big black ICs will have part number on them.
Jun 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-70707 rear projection TV
Try pushing Input and Menu together and hold them both in for 5 seconds to see if it blinks a 2 digit code which repeats itself. Then let me know what it does and we can go from there.
Jan 12, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Nothing happings
jen, Please verify Model # and mo / yr off the label on the back of your new set.................................T.
Nov 23, 2007 | Mitsubishi WS-55513 55" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Televison & Video Logo
408 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
