Question about Microsoft Windows XP Professional for PC
C language coding for vertical redundancy check method
  • 284 Answers
Is this for an assignment?
It might do you better if you figure it out yourself :)
Once you have a go post your solution here.
Someone might help you with it.
Check out codeproject.com.
That place is full of examples and helpfull people.
Posted on Sep 13, 2009
Howto remove door panel
You have electric windows in your pond? Lucky fish.
maybe if you can be bothered posting in the correct category with details of your vehicle someone might help?
by the way it's snapped not snapt, although I admire the available redundancy in the language.
Jun 17, 2014 | Garden
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How to find cyclic redundancy check ?
Cyclic Redundancy Check
The cyclic redundancy check, or CRC, is a technique for detecting errors in digital
data, but not for making corrections when errors are detected. It is used primarily
in data transmission. In the CRC method, a certain number of check bits, often
called a checksum, are appended to the message being transmitted. The receiver
can determine whether or not the check bits agree with the data, to ascertain with
a certain degree of probability whether or not an error occurred in transmission. If
an error occurred, the receiver sends a "negative acknowledgement" (NAK) back
to the sender, requesting that the message be retransmitted.
The technique is also sometimes applied to data storage devices, such as a
disk drive. In this situation each block on the disk would have check bits, and the
hardware might automatically initiate a reread of the block when an error is
detected, or it might report the error to software.
The material that follows speaks in terms of a "sender" and a "receiver" of a
"message," but it should be understood that it applies to storage writing and reading
as well.
The CRC is based on polynomial arithmetic, in particular, on computing the
remainder of dividing one polynomial in GF(2) (Galois field with two elements)
by another. It is a little like treating the message as a very large binary number, and
computing the remainder on dividing it by a fairly large prime such as
Intuitively, one would expect this to give a reliable checksum.
A polynomial in GF(2) is a polynomial in a single variable x whose coefficients
are 0 or 1. Addition and subtraction are done modulo 2-that is, they are
both the same as the exclusive or operator. For example, the sum of the polynomials
x3 + x + 1 and
x4 + x3 + x2 + x
Apr 15, 2011 | Computers & Internet
What is the basic code for html code for background
HTML Background Code This article provides HTML background code - code for setting the background properties of an HTML element.
The following examples use Cascading Style Sheets (CSS). CSS is the best way of setting the background properties in your HTML. It's more flexible than the (outdated) HTML method (more on that below). Using CSS, you can set the background properties of any HTML element. Plus you can do things like, specify an image's position, whether it should repeat, how it should repeat etc.
Background Color You can set the background color of any HTML element using the background-color property. You can choose a background color with the HTML color chart.
HTML Color Codes Use this page to get HTML color codes for your website. The colors are represented by their hexadecimal values (the most common method for the web). On the color picker, you can also see the RGB values (you can use these for the web too).
Example of HTML color code usage:
To learn more about HTML colors and how to apply them to your website, check out the HTML colors section of the HTML tutorial.
Mar 16, 2011 | EliteGroup Computers & Internet
How to turn on chinese writing for sony ericsson xperia x8
You need to make sure you have chinese input method installed. You may check this in the settings-> Applications -> Manage applications or setings->Language & keyboard. If not, you can find and install one from the Android Marketplace. One of the good one could be the Google pinyin. Also, the fashion Swype input method also supports chinese input as a beta function, but you have to root your phone to install this. After this, you can check the setings->Language & keyboard to enable and setup the input method of your choice.
Feb 28, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I need program source code for vertical redundancy check,longitudinal redundancy check,isochronous communication
#include<iostream.h>
#include<conio.h>
void main()
char bin[10],c;
clrscr();
cout<<"\n\n\n\nEnter 8 bit binary no.:";
cin>>bin;
cout<<endl;
for(int i=0;i<9;i++)
if(bin[i]=='1')
c++;
i++;
if(c%2==0)
bin[8]='0';
cout<<"Even";
else
bin[8]='1';
cout<<"Odd";
cout<<bin;
bin[9]='\0';
getch();
Feb 21, 2009 | Microsoft Windows XP Professional for PC
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
Jan 07, 2008 | Samsung i70 Digital Camera
Microsoft Windows XP Professional for PC Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
