Question about Acer X193W LCD Monitor
Inbuild audio speakers of acer LCD 193HQ monitor is not working. How to fix this problem?
  • Roberta Smith
    Roberta Smith May 11, 2010
    I guess the obvious needs to be asked. you have them plugged in right ?
  • Steve Dec 30, 2013
    right
    Problem Solver:
  • 6 Answers
There is no one good answer. This will require troubleshooting. Try connecting another source of audio into your monitor. For example, a mini-jack cable going from a portable CD player directly into your monitor would allow you to determine if the problem is on the monitor's end or the PCs.
Posted on Sep 04, 2009
    the problem is through the pc. how can it be fixed since it is probally in the setup???
How do I turn on the Acer AL1717 speakers?
the internal speakers, RTM it tells you how.
you plug them in to the PC, audio part conn.
then unmute the audio.
then up the volume.
also RTM the monitor OSD may have speaker enable , selection.
that is it.
Sep 26, 2013 | Acer 17" AL1717 Flat Panel Color LCD...
My HP 610 laptop's inbuild speaker is not working,but with the external speaker it is working.I want to know the price of HP compaq 610 inbuild speaker.
Try the following steps:
Open your laptop carefully (look out for fragile ribbon cables) !
Check for a broken wire going to the internal speaker.
Check for a faulty contact at the audio output jack (these things have a contact which disconnects the internal speaker when a plug is connected).
Temporarily connect any speaker in the place of the internal speaker.
If the problem is still the internal speaker, remove it and go to any good audio components shop and buy an equivalent speaker.
Hope this helps.
Nov 25, 2011 | Computers & Internet
Why is the sound not working on my acer screen
How do you have the screen plugged in?
If via HDMI, audio should go to your screen, but you may need to output to speakers (that is, if your monitor does not have built-in speakers).
If indeed outputting via HDMI, make sure your computer KNOWS it's supposed to output audio through the HDMI port as well as the video.
Finally, you might just need to plug speakers/headphones into the monitor - most have an audio jack on the underside, by the stand.
May 06, 2011 | Acer P221W LCD Monitor
I have no audio out. Buy my S243HLBMII monitor have a speaker and an audio input. audio input is only enable while I connect the lcd with vga cable. I want to disable the audio in and want to make it audio...
Hi lucasthehack,
I would like to help regarding your concern about the Audio issue you are experiencing with your LCD monitor using HDMI.
Since you are using HDMI you really do not need to look for an audio out to get sounds out of your LCD monitor.
- On your screen you will see a speaker Icon wherethe time is, right click on the speaker Icon then select Playback Devices.
- In the Playback Device Window you will see HDMI on the top of the list right click on it and click set as default, this will give you aduio out from the HDMI connection.
Restart you system with the HDMI conencted to the LCD monitor this should make the changes we made work using HDMI video and audio on your LCD monitor.
Thank you for choosing Fixya,
avf110686
Dec 21, 2010 | Acer S243HLbmii Widescreen LCD Monitor 24...
I HAVE JUST PURCHASED THIS MODEL SECOND HAND DO I HAVE TO GET SEPERATE SPEAKERS, I HAVE NO SOUND
look dear if the monitor dont have inbuild speaker then obviously you have to purchase new extra speakers ,,,it may also be the case that if it have speaker they might be no longer working..
Oct 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
No audio from my Acer monitor
check that the green audio cable is plugged in properley it does click a couple of times on its way in.
Mar 18, 2009 | Acer 22" X223w LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
No audio sound
Run the software that came witht he monitor, then check if you are sending the signal to the monitor and not your old soundcard.There should be
open "Open volume control" on the speaker icon in lower right corner of your screen.
click options/Properties
the "mixer device combo box" will give you all the options you can send the sound signal to, in my case realtek audio, webcam.
the acer LCD should be there, if not try to figure out why.
I dont have an acer monitor, but this should get you going in the right direction.
Mike
Oct 24, 2007 | Acer AL1715 17" LCD Monitor
Acer X193W LCD Monitor Logo
259 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
