Question about Xerox Phaser 8400 Laser Printer
Fault message 37,004.40
We replaced the printhead and have reassembled it. Now, after turning it back on, we get the following message: Service Needed. 37,004.40:112923. The message from the service manual says: 37,004.40: PEST - Printhead Reservoir 0 disconnect. Reservoir 0 is not drawing the
expected power from the supply.
WHAT DOES THIS MEAN AND WHAT DO I DO NOW?? Please help.
  • 430 Answers
Sir, you are having the problem after I provided the first solution to you. I'm nandini789. Sir, do you think that it is my fault.
Posted on Sep 04, 2009
  • Nandini Dhar
    Nandini Dhar Sep 04, 2009
    You can take the following tests to make sure for errors:-
    1. Run the printhead Reservoir Heater test.
    2. Verify printhead wiring.
  • Nandini Dhar
    112,923 is the page count. As far as the error goes. Sometimes this can be cuased by a voltage sag on the circuit due to the extreme amount of power used to warm up this machine. Always plug straight into a wall outlet. Make sure no other large appliances are on the same circuit such as personal floor heater, another laser printer, copier, coffe makers, etc. Xerox recommends trying another circuit. The reservoir is in the printhead. the ink loader melts the sticks and they drip the ink into the reservior where it is heated until it fires out the printhead nozzles. Another thing that can cuase this error is being moved while the ink is hot. The reservoirs are not sealed on top so it can spill out and damages the printhead board or wiring. Usually though it comes down to the printhead which arent cheap. Thank you.
  • 154 Answers
That error code means that you need to replace the Printhead, maybe the printhead power supply failed, and not receiving enough power to function. Call your manufacturer and they will send you a printhead.
Thanks
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | The Office Equipment & Supplies
My Canon iPF8400S displays a hardware error 03130031-2F4D message. What does it mean?
Hi
"VHT leak detection error of left printhead,
in case of VHT exceeds rated value or falls
below the rated value."
So, error shows left printhead feeding voltage problem. It can be result of fault:
-printhead;
-Carriage relay board;
-flexible cable
-main controller.
Low speed of printing can be when printhead have overrange with it temperature; and when printing, printer makes a pauses to cold printhead. More information you can get from file PRINT INF under SERVICE MODE.
If you are a "ordinary user", looks like you can only try to change left printhead (success not guaranted!).
Dec 12, 2016 | Canon imagePROGRAF iPF8400 44in Printer
Print head
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Mar 25, 2014 | HP DesignJet 5500PS InkJet Printer
HP Photosmart B210a error message
Simple. Remove the ink and printhead. You can remove printhead by pulling gray latch up and sliding printhead up and out. Clean printhead gunk off using warm running water. Remove any ink gunk on the right side of printer if you see any. Turn printer off and on. See if problem went away. If it did, try putting the cleaned printhead inside printer again. If problem comes back, seems like the issue is with a bad printhead. Below are video instructions on cleaning head manually. The printheads are not same. B210 printhead is not the same with HP 6500, but instructions are same.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 07, 2017 | HP DeskJet F4280 All In One Printer InkJet
Message on printer screen says "The following printhead(s) has a problem: black/yellow (K/Y).
This probably could be defective Printhead ( black/yellow )
Follow the steps below and it should resolve the issue, if not, you need to replace the K/Y Printhead. You can purchase it from any nearest departmental store like bestbuy or costco or walmart etc or Call HP and order one.
Open the front access door. ( printer must be power on )
Remove the Latch of the Printheads
Clean the Contacts with lint free cloth ( golden contacts or electrical contacts / not the nozzles )
Re-install the Printhead back in its position and close the front access door.
The printer usually goes thru initialization process. or Turn off the printer and turn on.
If you still get the error message, Replace the K/Y Printhead.
Regards,
Ron
// Rate this solution with 4 Thumbs to help us improve the support
Jul 02, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
We just bought the Pro901 about 3 weeks ago and it has been working fine until today when we got a "Printhead" error. Following the instructions on the machine we removed the printhead and wiped...
Updating the firmware for your Lexmark Pro901 printer will help fix the problem. You will need to get rid of the error first before you can successfully update your printer. Follow the steps below:
1. Open the cover of the printer > remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Home icon.
4. It should take you back to the Main menu.
5. Proceed with the firmware update, go to http://bit.ly/p905fw.
6. Once the firmware update is successful, you may reinstall the printhead. Follow the steps on the printer screen.
Source: There is a Problem with the Printhead
May 20, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
HP Designjet 500 24-in Roll Printer error message 2110
Service Station failure. The possible cause could be:
The steps counted by the Service Station motor are not consistent with the expected length of the current movement.
The Aerosol Fan has reached its maximum current limit.
The Service Station motor has shutdown because of blockage.
8x8.gif Corrective Action 8x8.gif 8x8.gif Try the following:
Remove ALL the Printheads and clean the flex contacts on the Printheads and in the Carriage Assembly.
Replace ALL the Printheads.
Replace the Service Station/Aerosol Fan Assembly
Apr 05, 2010 | HP DesignJet 500 InkJet Printer
Xerox phasor 8400 - fault 37,004,40:157517"
Hi I can gave you some error codes but this all I can do hope it be of help to you.
8,009.4x:CAP_FAULT_MP_NO_ CLUTCH_STALL:
  • The media path motor has stalled while moving without the clutch engaged.
33,001.4x - TM_DEV_FAULT_MPT_WIDTH_VALUE_TOO_LOW
  • Tray 1 status:
1. Check the wiring and connectors from the front door to the I/O board.
2. Run the Test Tray 1 Width Sensors.
3. If the test fails replace the front door.
4. Replace the I/O board.
08.055.44:
  • The media path drive module has stalled while engaging the head tilt.
37,008.44:
  • The Preheat preheater is not drawing the expected power from the supply.
Run the Preheat Heater test, check the wiring. If test fails and no apparently problem is evident, replace the preheater.
05,002.42:
  • Problems with the Y-axis. It could be the belt,motor or the drum.
7,008.4x: PM_FAULT_HEADTILT_NOT_ ENGAGED
  • The printhead tilt is not engaged, so it didn't tilt back properly or the printhead is stuck in the tilted position by the tilt lock arms. The process motor gear train getting out of sync can also cause this error.
1. Try rebooting the printer.
2. Check for an obstruction or damage in the process gearbox.
3. Ensure the gears are correctly aligned and homed. If faulty replace the process gearbox
assembly.
4. Run the Tilt Axis Drive test to test the headtilt.
5. Run the Head Maintenance Wiper Clutch test. If the test fails, replace the wiper drive clutch.
6. Run the Wiper Axis Drive test.
7. Replace the exit assembly.
7,010.4x: PM_FAULT_HEADTILT_HOME_ERROR
  • The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can also cause this error.
1. Reboot the printer.
2. Verify the lock arms rotate correctly.
3. Check for spilled ink around the printhead.
4. Check the process motor gears for damage. Ensure the process gears are correctly aligned and homed.
5. Verify the process gear box, process shaft, and drive module shaft are at home position.
6. Verify the headtilt gear will engage, see the home positioning procedure on page. You can manually engage the headtilt gear.
7. Run the Tilt Axis Drive test.
8. Run the Process Motor test.
9. Run the Head Maintenance Clutch test, if the test fails replace the clutch.
10.Run Wiper Drive test. If this fails inspect the wiper drive system.
All The Best: Pineworks
Jan 05, 2010 | Xerox Phaser 8400 Laser Printer
Service message: Fault 37,004,40:50081
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
May 22, 2009 | Xerox Phaser 8400 Laser Printer
Error in xerox phaser 8400
One of the printhead cables may have come partially unplugged. Also, an ink spill on the circuit board could lead to this problem.
Apr 13, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
24 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
