Question about Linksys Wireless-G WRT54GS Router (e125894)
Need install disks for wrt54g wireless router
  • 1,511 Answers
Hello and Welcome to FixYa!
You download the software needed to configure your Linksys wireless router from Linksys website.
If you have version 7.2 click below
http://downloads.linksysbycisco.com/downloads/WRT54G-v7.2_Setup_Wizard,0.zip
If you have version 7.0 click below
http://downloads.linksysbycisco.com/downloads/WRT54Gv7-EU_v7_00_4,0.zip
If you are not sure, try anyone.
If i was helpful, kindly do rate me.
Regards,
Waqar
Posted on Sep 04, 2009
Software here https://docs.google.com/file/d/0B3aec1XMo6pyQkFQODFNb1poRXc/edit
Posted on Jan 26, 2013
  • 404 Answers
Hi ktrawick1! here is the link to download your setup wizard disk, but I can also give you the step by step procedure just in case the setup wizrd was not able to configure your router.
here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the innternet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
  • 256 Answers
what installation disk you need for wrt54g. you just need to configure it .for that just connect it with Computer using lan cable. then give a static ip to your pc.ip should be of same series of that on router. eg 192.168.1.2 you can because the default ip of this router is 192.168.1.1 now using the internet explorer type the address \\192.168.1.1 if you donot change the default ip till yet . now if your router is properly connected to computer then it will ask for username and password. default user id and password is admin , admin for this router. If router accept this id and password then it will open for configuration.you can configure it there. if default id and password and ip address does not work then you can also reset it to default setting by using a button on the back side of router in between ethernet pot and antena . to do that just keep pressed that switched with any niddle or pen and power on the router for one mnute only . it will reset it to its defualt setting
    President:
  • 392 Answers
Click here for the installation disks software
Where to download the installation disk
Are you trying to setup router?
You can install your router manually.
You don't even need to run the CD>
Just open the setup page of the router and change the Internet connection settings manually.
See Linksys router setup
Jan 07, 2012 | Linksys Wireless-G WRT54G Router
I need to install my rouder but dont have install disk
Here is the link for you down load you will need to put in your version number and then it will go to the down loads
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
Aug 23, 2011 | Linksys Wireless-G WRT54G Router
Need to configuate my router to my computer
The router should come with a CD Disk for the installation if you are missing the disk visit cisco's support page and download the necessary guides and software.
Mar 21, 2011 | Linksys Wireless-G WRT54G Router
I was given a router but i dont have install disk linksys model wrt54g how can i install it
no install disk is needed
Connect the Router (Up link to modem, Port 1 to computer) Boot computer, you should get an IP address in the range of 192.168.1.xxx Open a browser (IE/Firefox etc) on the address line type 192.168.1.1 press enter You will be prompted for a username and password. Leave the username blank, password= admin Once logged into the router, you can set the wireless settings then save and then you can connect via wireless. For Wireless security codes, you can use the default suggested by the router, or as I recommend, use an old 10 digit phone number as WPA key 8009993355 for example as it is generally hard to guess but easy to remember.
here is more info if needed
http://www.ehow.com/how_5133173_set-linksys-wrt54g-wireless-router.html
Dec 24, 2010 | Linksys Wireless-G WRT54GS Router...
Wireless problems
You'll needing to access the configuration page of your router (ei 192.168.1.1), to make it accessible you'll needing to create a wireless network name and security or encryption to the router (ei WEP or WPA)
Mar 08, 2009 | Linksys Wireless-G WRT54G Router
I bought a wireless router wrt54g and I dont have the disk to install it so what can I do?
You won't need the disk.  You can plug your computer directly to the router.  From there it should receive an IP address.
Go to Internet Explorer>192.168.1.1>enter credentials, then you can setup your wireless settings.
Use window to manage your wireless services.
Feb 01, 2009 | Linksys Wireless-G WRT54G Router
My computer deleted my router when i got it fixed and i dont have the disk to re-install?
The setup wizard installer for a LinkSys WRT54G may be downloaded from here. Please select your version number.
Good luck and kind regards.
Feb 03, 2008 | Linksys WRT54G Wireless-G Broadband Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
2,224 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
