Question about Sony Handycam DCR-TRV250 Digital Camcorder
Can't record through A/V cable
I am unable to record vcr or tv through the A/V cable supplied with the Sony DCR-TRV250. It works fine sending the signal to a TV or VCR but will not take a signal in. I have tried following the directions in the manual with no success. Everything else seems to work fine
  • Anonymous Apr 05, 2008
    I have the same problem. I read the manual carefully and found out that only 350 and 351 support the A/V cable. To record from the VCR to this TRV250 you need I.link cable and a VCR with DV i.link out put
    Sergeant:
    Champion:
  • 231 Answers
Make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
Posted on Dec 07, 2007
The LCD is blue and won't play back . We have cleaned it. Camera mode works when recording. Just no playback picture in VCR mode. ...
you most likely has a bad screen, if you can, play back your video into a VCR, dvd burner or televisino with rca type inputs, this will at least let you save your movies.
Mar 18, 2011 | Sony Handycam DCR-TRV250 Digital Camcorder
I need help with my Sony DCR-TRV250. I am trying to play a tape on my VCR and record onto my Sony Camcorder.
I believe that this particular model does not have an A/V input. The A/V jack on the camcorder is output only. This link will provide all of the specs on this camcorder.
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&productId=11040477#specifications
Hope this has helped you in some way.
www.austintelstarservices.com
Sep 04, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
I get a blue screen and won't let me record
The dcr-trv250 has to common problems that apply to your camcorder. Bad iris or bad ccd imager. I've seen about a 100 of each lately. Look into the lens while you turn the power off then back on into camera mode. You will be able to see the iris open. If you don't see it open then it's most likely bad. Larry's Electronics Sacramento Ca. 916-362-8708 ledstiles@hotmail.com
Apr 23, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
My sony dcr-trv250 ntsc does not play videos that were recorded on my old samsung scx904 or alittle older sony that my father in law had let us borrow before we got ours...why? and is there some way to...
Your DCR-TRV250 uses a Digital 8 system to record and playback information on its cassette whereas the older Analog 8mm machines used the analog system. Unfortunately the two are incompatible.
Jan 02, 2010 | Sony Handycam DCR-TRV250 Digital Camcorder
I have a sony digitalhandycam(digital 8)and cant seem to transfer to my laptop
I have a digi8 DCR TRV140E - The USB does not recognise, windows does not recognise it and the only method that works to edit from the tapes recorded to pc is fire cable - try that folks at least it will hold you back from smashing the camera!!
Oct 18, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony digiital handycam dcr-trv250
You are probably looking at around $100 repair to get the mech sub chassis, with the reel sensors replaced. Please, if you approve of my information, please be sure to rate it. Thanks!
Oct 29, 2008 | Sony Handycam DCR-TRV250E Digital...
Recording from a vcr
check a/v imput on camera settings, make shure that u have audio alsso conected, tried to use diferent output (DVD), make shure is playing .,
Feb 03, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Sony Handycam DCR-TRV250 Digital Camcorder Logo
93 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
