Question about iLO 3200 32 in. LCD Television
My 32inch ilo tv is stuck on one channel and i cant get it to work and remote wont help.
  • 10,515 Answers
This is a very a known issue with this set that caused a recall on this unit.
This is a unbelievable mistake by an engineer... He coded the remote wrong.... Let me explain.
On most set the remote works on a frequency that is locked to each button and each button has a very perfect frequency that is keyed to it, not on this remote.
The remote was built with the frequencies not set properly at the factory and when it got bad data from the remote the micro blows on the sets main board. I have spent weeks trying to bypass the data line no go they connected both the buttons on the set (less the power button) and the remote buttons on the same data line.
The only fix is to replace the main board and guess what it comes with a remote, they covered this under a warranty up until september '08. Mintek/Initial and ILO all had this issue (initial built all of them)
The new board comes with new software and new coding on the remote.
It should be around $100-150. I paid 108+10 s/h on mine (it was a ilo32hd and the part number was MPCB-E22440 ask them for a main board and they will provide the part number) Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 04, 2009
I cant get to inpuit
My tv wont change channels. Its on a cable box but wont let me put a dvd player on or cant scan channels. Dont have a remote.
Nov 08, 2010 | iLO IWT3206 TV
TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
May 16, 2009 | iLO 3200 32 in. LCD Television
Remote brpke for my 32" ilo sdtv.. need help
The only remote I was able to find that work all Ilo features is the GE universal remote #24914. The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.If you don't have satellite or cable you might need a digital antenna.
Feb 19, 2009 | iLO IWT3206 TV
Ilo 32 in
Try the keys on the set I would think there is a menu key there on the set to help get you out of favorite channels. Universal remotes don't always work as thought should be and usually onthe the devices remote will access all functions. Is our remote dead or busted? Try opening it up look for bad solder on the circuit board clean the switch contacts on the the board it may just fix it
Sep 03, 2008 | iLO 3200 32 in. LCD Television
Ilo tv
The Sony RMV210 remote will work on the 32inch Ilo and other HD tv's, that what makes it cost so much, but it will work
Nov 22, 2007 | iLO 3200 32 in. LCD Television
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
NaviLight8 universal remote
There are no codes for ILO products. You have to get VERY lucky to find a universal remote that works with them. It's just one of the drawbacks for this brand of TV.
Jun 09, 2007 | iLO 3200 32 in. LCD Television
Ilo 32inch LCD TV
better off throwin television out on trash day saves money on tylenol
May 15, 2007 | iLO V27DMBX Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
44 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
