When It goes to loading screen it restarts
When I turn on my computer it loads a black page that asks me to "start safe mode" or "what recently worked last" or "start windows normaly" so i go start windows normaly then it goes to the black loading screen with the logo then the computer restarts it does the samething over and over and it dosent change if i go start safe mode or what recently worked last.
  • 4,281 Answers
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 04, 2009
Testimonial: "thank u very much its running great thank u"
So my laptop froze yesterday and I turned it off to restart it. When I restarted it it everything was normal but after the starting windows goes away it usually goes to the login page well now all it does...
Try starting it in safe mode.
When the computer is starting just after the beep or when the bios info goes away press f8 repeatedly and you will get an option to open in regular or safe mode.
Alternativly you can also hold down teh ctrl key and it should do the same.
Did you install or update and drivers recently?
Aug 25, 2011 | Compaq Computers & Internet
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
Computer is not loading..black screen keeps coming with the message input not supported..how can i turn my computer on normally.it loads on safe mode.
Input not supported could be the screen having problems. It loads in safe mode so the display driver is corrupt or set to a too higher resolution for your screen.
Adjust it as required.
Jan 08, 2011 | Computers & Internet
My computer is having start up issues. When I turn it on it'll act like it's loading normally and then it'll beep twice. It'll go to a screen that will have several ERRORs on it and ask me to press either...
It may happen when CMOS Checksom error i.e error may happen due to keyboard failure. Please follow the steps to short the BIOS
> Open the Laptop back panel. Locate the CMOS battery, remove it & then with the
help of a screw driver keep on pressing the terminal inside it and turn ON the computer for 10 secs and Turn Off (make sure you keep on pressing the terminal with a
screwdriver while turning ON). It will short the BIOS setting. Now, fix the CMOS battrey & restart the computer. This will take care of the issue.
Now, restart the computer in normal mode. If still facing issues then I would suggest a full system recovery.
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 28, 2010 | Acer Aspire 5100 Notebook
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Feb 18, 2010 | Computers & Internet
Hi my laptop turns on and goes to the windows
If it starts to load the operating system and then the display goes black then chances are that the dispay/video drivers are corrupt.
Boot the machine into safe mode by restarting the computer and repeatedly press the F8 key as it starts. This should bring up a sub menu with safe mode at the top. Use the cursor keys to highlight safe mode and press enter.
You will see white boot information scroll up the screen, be patient and wait for it to load up.
Click on your account and you will see a message about system restore. You don't want to use system restore so click on yes to work in safe mode.
Right click on My Computer/Computer and click on manage from the list. Then select Device Manager.
Look in the list for display adapters and click on the + or > next to to expand the list. Right click on the display adapter and select uninstall.
Restart the computer and it should load up the operating system and reinstall the drivers for the display.
Regards.
Nov 11, 2009 | ASUS Eee PC 901 XP Notebook
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Blank/Black Screen Asus PC 4G
When you first turn on the computer, start tapping the F8 key to bring up the safe mode screen. You have a very short window in which to press the F8 key before XP loads, so it is possible to miss it. If this happens, just restart it and try it again. Once you are on the safe mode screen, select the enable VGA mode. This will boot your computer to a default 640 x 480 resolution so you can change it back to normal.
Thanks and please don't forget to give this solution a fixya rating.
Jan 26, 2009 | ASUS Eee 4G Notebook
Laptop won't comeback on
Try safe mode.
On safe mode return the computer to an earlier date configuration.
At some point will ask if you want to do that. And say yes.
Make sure that if for some some reasons it asks you to restore the computer to factory settings, you should say no. I hope you can do this.
Mar 31, 2008 | Toshiba Satellite 1405-S151 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
