Question about RCA Televison & Video
RCAP56740BG Arc's inside when you try to turn it on
  • RCA Master
  • 1,213 Answers
Your flyback transformer is preparing toast. It needs replaced immediately. Don't power up your tv, you may further the damage. Orange juice anyone?
Posted on Sep 04, 2009
Undefined
When your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD is connected to a wireless network, you'll see a and-wififull.svg Wireless icon in the System icons at the top of the screen.
  1. Tap the and-home.svg Home icon at the bottom of the screen.
  2. Put your finger at the top of right of the screen and swipe down.
    The Settings shortcuts will appear.and-shade.svg
  3. Tap the and-settings.svg Settings icon.
  4. If required, tap the slider button beside Wi Fi at the top left of the screen. The button will turn blue and display On.
  5. Tap Wi-Fi. The list of available networks will appear.
  6. Tap the name of the network you wish to connect to.
  7. Tap Connect.
  8. If you see a lock icon beside the wireless connection, it means that the connection requires a password. You'll need to enter the password to connect.
Turning off Wi Fi on your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD You can turn off Wi Fi to keep your Kobo Arc 7, Kobo Arc 7HD, or Kobo Arc 10HD to keep from connecting to the Internet, which is also known as Airplane Mode.
Turning off Wi Fi extends your battery life, and also lets you use your Kobo tablet on an airplane or in a hospital.
  1. Pull and hold the power slider at the top of yourKobo Arc 7, Kobo Arc 7HD, orKobo Arc 10HD until the power off menu appars.
  2. Tap Airplane Mode.
Oct 27, 2014 | Tablets & eReaders
Tip
Prone to arc eyes from welding?
If you have a conventional flip lens welding helmet and are prone to getting arc eyes from "peeping" though a gap to strike your arc, try this.<br /> Replace the inside fixed clear lens in your helmet with a yellow perspex lens. The world will appear strange at first through the yellow lens, but the yellow cuts out the ultra violet rays that cause arc eyes. The yellow lens should not be considered a replacement for the dark glass, it is only to shield you from that inadvertant flash when making your strike.
on Jan 19, 2011 | Welding Tools
Picture is getting dark.
Try changing the lamp, some times as they age the electrodes in the arc lamp evaporate and depositing inside the arc tube, causing it to darken, if the lamp is clear there is a good change that the light tunnel is broken or has other problems with the light engine
Jul 05, 2014 | Samsung HCM4215W 42" Rear Projection...
Error when using inverse trig inever used to get these errors when trying to find angles using whole numbers inside the inverse trig functions but now it will only calculate SOME fractions. wether the...
If you are trying to calculate arcsine (sin^-1) and arccosine (cos^-1) the only whole number you can use are -1,0 and 1. This due to the fact that the domain of these functions is the closed interval [-1,1]. Any value outside that interval will trigger an error message. No limitation on the argument of the arc tangent or arc cotangent functions
If the angle unit is set to degree the arc will be in degrees, and if angle unit is radian, the arc will be in radians.
Sep 27, 2011 | Texas Instruments TI-84 Plus Calculator
Thermal Dynamics Drag Gun Pac 10, Push Trigger, Labored Sound, Cuts Off and wont cut or flash arc. Cleaned Air Filter allways, All New Consummables, Allways kept clean, Has a rattle when trigger pressed...
Hi:
Your plasma has a start arc pilot inside the machine, this one must be faulty, check your owner's manual and request the part to your nearest welding store. It is easy to replace.
Jun 21, 2011 | Welding Tools
There is the liquid seeping out of the breakers, it is not water the box is dry and it feels like an oil of some kind. breakers are working and are not hot. i have not seen this before. what is it and what...
It is oil. It's used to extinguish the arc.
When a circuit breaker trips, there is an Arc of electricity made inside the breaker, due to the contacts.
The contacts are instantly brought away from each other.
There are three methods employed to extinguish that arc.
[Extinguish the arc. Non-technical explanation. With out some medium to extinguish the arc produced inside, it would go Z-z-z-z-z-z-z-z-z-z-z-z-zap, instead of z-zap]
Oil, Air, and Sulfur Hexafluoride.
So yes, as long as the circuit breaker doesn't have to trip, and produce the arc inside, it is a working circuit breaker.
Is it a safe unit?
NO
The method employed to extinguish the arc if the breaker trips is leaking out.
Replace all breakers that are doing this.
Average cost for a GE single-pole 15, or 20 Amp is around $11 here. A few dollars more for 30 and 40 Amp, but usually double-pole breakers are used for 30, and 40 Amp.
Nov 18, 2010 | GE Circuit Breaker THQB BoltOn 1 Pole 15...
I dropped my computer with the transceiver for my arc mouse in it, bending the transceiver and rendering it unusable. Can it be replaced? How do I get a replacement for it?
Each mouse is synced to only the one particular receiver, so no replacement. But do try calling Microsoft. The Arc comes with a 3 year warranty, and 90 days technical support. Tech support time starts from your first call to them, not from purchase date. You'll need the Product Identification Number which is inside the battery compartment and labeled "PID".
I just worked with them to get help for my Arc that just refused to work after a year, and they are sending a replacement.
Nov 10, 2010 | Microsoft ARC Mouse
Unstable arc..Millermatic 250. arc not steady
Your windings inside are aluminum, they may have loosened up where the positive lead hooks on to the transformer inside.
I had a miller and the wire melted there, you can re-loop the wire and re-fasten it if it melted short enough if this is infact the the problem when you take the cover off..
Dec 19, 2009 | Welding Tools
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
WIRE FEED BUT NO ARC
Turn off welder, unplug and press trigger to discharge any possible stored juice. Then, open side door and check the ground cable where it connects inside, it sounds like either ground or the hot is off. Once you determine those are both securely attached, close door, plug in power on, attach ground clamp to test piece off metal and try it again. Let me know if this helps! Thanks:)
May 08, 2009 | Welding Tools
Televison & Video Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
