Televison & Video Logo
Posted on Sep 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv lock turned on and can not unlock
Muller tv on child lock on and can not turn off
Anonymous
Level 3:
  • Master 458 Answers
  • Posted on Sep 04, 2009
Anonymous
Master
Level 3:
Answers
458
Questions
0
Helped
217351
Points
1225
Need tv model or you try 0000 or 9999 or 7777
may be ok .
Logic locked tv is locked ineed apassword
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Hundai tv child lock,cannot open the tv
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.To get more details, http://electronicshelponline.blogspot.com/
2answers
How to get child lock off of my daughters TV I forgot the code help!
The procedure to unlock the child lock to TVs will differ brand to brand. The general procedure to most TVs are:
Check this. If you wish to get more details about unlock a TV, check the site linked here. Pull up older posts. Unlock procedure to many popular brand TVs are given in detail.
google.com/+GopakumarGopalan
2answers
Child lock on in LC-T32HV
2helpful
How to unlock the tv
How to remove child lock
Child lock on no remote
1helpful
My TV is on child lock how do I unlock please
  1. Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
  2. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
  3. Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Read more: How to Unlock the Child Lock on a TV ' eHow.com http://www.ehow.com/how_4510749_unlock-child-lock-tv.html#ixzz12VdKs6Bt
3answers
Help me please................................
Usually, once child lock is on, the set will not respond to the front panel buttons and you need the power button on the remote control to turn the TV on. Then go into the menu and turn child lock off.
8helpful
3answers
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
