Question about Umax PowerLook 1100 Flatbed Scanner
I have Driver and a card slot to work it with 98 and desktop now I want it running on a laptop and on xp witch do not have 6pin firewire plug so i got 6pin to usb firewire help me run umax powerlook on my laptop and with win xp
  • 4,924 Answers
  • Catalin Turcu
    Catalin Turcu Sep 04, 2009
    just choose the model and the operating system ...I do not think that update it on usb will make any troubles ...but let me know if it does...
Can I install a GTX 9800 on an Acer Aspire m1641?
The model number of the mainbaord is usually printed on the mainboard itself. Look between the RAM dimms near the CPU socket.
If that mainboard is PCI-Express then it will be fine. It's PCI-Express if your card fit into the slot and locks into position. If the slot is too small for your card then you know that the board is some-thing else.
Just make sure the Power supply has at least a 6Pin Power connector for that graphics card.
The 6Pin connector plugs into the actual graphics card at the top. Be sure that the power supply is rated at 450Watt +.
Install the lastest drivers from the Nvidia website.
Take care!
damnor01
Sep 16, 2012 | Acer Aspire M1641-U1521A PC Desktop
I have a SONY HandyCam DCR-SX44. I want to transfer video/audio directly from the camcorder to Windows Movie Maker. I have a cable with USB connection on one end and 5 pin connection on the other, but...
I had similar problem with my Sony Digital8 (also called HI8 ) handycam. My vista system was not able to detect my Handycam with a very very cheap FIREWIRE PCI Card I bought in local market for only $4, yes four dollars. It came with 6pin to 4pin Firewire cable(Sony calls it i.Link). I was trying to connect with same cable 4pin at camera end and 6pin on PCI Card, with no luck. It was even showing DV-IN on camera LCD with this 6pin to 4pin cable. I tried everything an expert would do, but got only frustration. Even tried a lot on Internet for the solution but it seems no one knew.
Then I started from scratch, TO DECIDED TO READ MANUAL. While reading the PDF manual found on Sony Support site, trust me, I found those golden words "USE ONLY 4PIN TO 4PIN i.Link Cable for Firewire connection."
I ran back to market and bought 4PIN TO 4PIN Firewire Cable for $1.5
At first trial, trust me, it detected "SONY DV Camcorder" and installed drivers automatically. I confirmed by going into Device Manager and found same entry in Imaging Device section. Then what in every possible software existed on my system, DV Capture was available, which was found always disabled.
Now the funny part it, technically there is no difference in 6pin to 4pin Firewire cable as two pins are used for Voltage which is discarded at 4 pin end. But it seems SONY Handycam does not wants itself to connect it to 6pin socket at PCI card end.
So these are the final things to remember.
1) Use only 4pin to 4pin Firewire cable (any cheaper make. $1.5 will do)
2) Use any cheaper FIREWIRE PCI card with at least one 4pin firewire socket. When installed XP or Vista will install driver automatically just confirm that "IEEE 1394 bus host controller" entry is shown in Device manager or not.
3) No matter you use cheaper or costlier PCI card or cable the quality will always be same coz D8 Handycams directly transfer encoded Video Data in Digital format thru Firewire cable. Firewire cable does not transfer RF video input. I get default video with 720x576 with 25 Frames/s in PAL mode.
4) No additional codecs are required to install in pc like others suggested. Required codecs are always there in XP and VISTA with windows movie maker.
5) No additional software is required, as you can directly capture with Windows Movie Maker in high quality. My choice is Adobe Premier CS3. If you want to make directly MPG file you may use ULEAD VIDEOSTUDIO 8 or later.
6) Do not blame non.gif SONY as they already told you which exact cable to use.
7) Do not blame non.gif Vista. Its nothing to do with it. Sony's PicturePackage for XP does not work on vista. For vista they offered PICTURE MOTION BROWSER which also have easy VIDEO Capture utlity with same high quality capture. Some people falsely claim that "VISTA DOES NOT WORK WELL WITH FIREWIRE" That is completely wrong. See, one or few people may have problem and they always keep shouting for thier fate. But it actually it could be thier local hardware or software problem or anything. There could be many reasons at the same time too. Many people even do not care to change to new cable and keep trying on same thing. Actually cables are very delicate rubber material. Many a times you get faulty cable in new petty pack box of devices. Or it could be some firewire chipset problem too. Last is driver problem. Many firewire card manufacturers have not yet made stable drivers for vista. Most problems are solved if newest drivers are downloaded and installed.
7) In handycam mode, you can control PLAY/STOP/PAUSE of Handycam from PC itself from all the video software you use, which is high convinience for capturing.
8) My sureshot capture sequence is as follows.....
a) Remove BATTERY from camera and switch on with AC Adaptor
b) Put it on PLAY/EDIT mode (also called VCR mode).
c) Connect 4pin to 4pin firewire cable on camera side and in firewire PCI Card. Now you see the words DV-IN on LCD of camera, if LCD is open.
d) Now start any Video Capture Software of your choice. You will find CAPTURE command in FILE menu in almost all softwares.
e) Enjoy.....
Jun 26, 2011 | Sony Video Cameras
Can I connect a firewire to my Dell Inspiron e1505?
Yes, right side last port toward the hinge. Below is a link for both the user and service manuals.
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
Sep 13, 2009 | Dell Inspiron E1505 Notebook
Wireless help
My dear! alway remember that when you use any new hardware you should install driver first and then plug it with CPU. So it could be possible that when you install driver first then card will pick and work properly.
Thank You
Jul 26, 2009 | Acer InviLink 802.11b (91.49C10.002)...
Mine is an aspire 5535. Need an express card for use with Firewire. Camera has a 4pin Firewire
http://www.newegg.com/Product/Product.aspx?Item=N82E16815108013 so you need something like this? will fit in to any old pci slot (not pci-e slots) witch most mobos have 3-5. hope it helps
Jun 10, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
I need to have copmuter card that is to down laod from JVC DVC GR- D750AS. and what is the name of the card.
If this is a MiniDV camcorder (record to miniature digital tape) then you will need a firewire card.
Use these links as references:
For a desktop
For a laptop w/ PCMCIA
For a laptop w/ ExpressCard
You will also need a firewire cable to connect your camera to the card. If you dont have one search for a firewire 4pin to 6pin cable... such as....
this one
You can use software such as windows movie maker on XP or Vista to import your video...
Nov 15, 2008 | JVC GR-D770 Camcorder
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
FW-1804 sounds keeps skipping and cutting out!
I've tried multiple times to set up the 1804 with my mac pro...so far no go...the computer hasn't been recognizing the unit. I've installed, uninstalled, reinstalled a few times, made sure I had the right 6 pin fw cable, plugged it in when prompted, and still, the control box of the 1804 states there is no available device. I did downloaded the most current version. Before I go through this process again, do you have any advice on some more possible kinks?
Apr 04, 2008 | Tascam FW-1804 Sound Card
External sound device not working
Hi, What you probably need then is a 6 to 4 firewire converter (IEEE-1394). Should you want to build your own, this site offers the pinout connections > http://www.interfacebus.com/Design_Connector_Firewire.html Should you want to purchase a ready made converter/adapter, it is available at http://www.afterhours.co.uk/sitecom-firewire-64-pin-converter-p-497.html or google for "firewire 6 to 4 cable converter" Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 02, 2007 | ZT Group Cisnet T2060 Notebook Computer
Techgear 3-port 1394 FireWire CardBus
Jim, Have you run the add hardware wizard? Are your pcmcia card slots enabled? If not in Control Panel then in the BIOS? Good Luck, Tim
Feb 06, 2007 | A D S GBR-101 (GBR101) Serial Adapter
Open Questions:
Umax PowerLook 1100 Flatbed Scanner Logo
82 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
