Question about Xerox Phaser 8500N Printer
Heater harness plug direction in reassembly?
We have replaced the printhead and are reassembling. One question at end: What direction should the heater harness plug and two ink loader harness connectors go in? It is not obvious which side is up. Help please!!
  • melodyb Sep 04, 2009
    Thank you.
  • 430 Answers
Https://www.office.xerox.com/partners/products/Phaser8500/SQRG/10_wiring_diagrams.pdf Sir, you can go there to view the wiring Diagram. Thank you.
Posted on Sep 04, 2009
I have a chrysler grand vouager an the electric sliding door does not work
Contact your local chrysler dealer. The wiring harness/track has been recalled due to them starting fires. If you vehicle is covered they will take of replacing the track/harness. If it is not covered a new harness is about $80 to $100.
If your good with automotive wiring you can remove the harness and replace the broken wire(s). You will see the harness plugged into the lower part of the door. The other end plugs into a connector behind the B pillar trim. Once it it out the tape and shielding can be removed and the broken wires will be pretty obvious. Take some pictures of everything to help reassembly it when your done.
Oct 05, 2010 | 2000 Chrysler Grand Voyager
My dads 1989 suburban won't start
Sounds like you have a dead short coming from the new fuelpump you just put in. Find the wiring harness plug coming from the sending unit and pull it apart and see if it is a green color. If it is try cleaning the ends of the prongs on plug,put back together and try it.Also did you happen to pinch the sending unit wires between the tank and mounting straps when you reassembled it?I hope this helps
Feb 20, 2010 | Chevrolet 1500 Cars & Trucks
I HAVE A 1994 BUICK LASABRE LTD. THE ROUND HARNESS PLUG THAT PLUGS INTO THE TRANSMISSION,APPROX. 1'' IN DIAMETER,WITH CONTROL CIRCUITS FOR THE SOLENOID SHIFT COILS,AND TEMP SENDER HAVE BEEN PULLED OUT OF...
Don't bother,you can by a new plug in with pigtail(wires) from any GM dealer.Trying to reassemble one of those would be maddening and probably wouldn't work anyway.Perhaps you could even get one from a salvage yard,then splice the wires according to color.Take care.
Dec 21, 2009 | 1994 Buick LeSabre
Optimus heater h-4438
Check on the heater coil using the multi-tester. Set it at Ohms 1 x 10 position.
1. Switch it off and disconnect it .
2. Disassemble the electric heater.
3. Put the multi-tester probe (red and black) at each
end of the heater coil.
4. If the reading is almost zero, then it is okey.
Otherwise, you have to replace it.
5. Then, reassemble the electric heater.
6. Plug it back to the electric outlet, and switch on.
Nov 03, 2009 | Optimus H-4436 Electric Heater
Check hopper connector
Open front cover. On the right side towards the top, there is a grayish small cover with a black phillips head screw. remove this screw. Remove the small cover. Underneath this cover is a plug that connects the toner hopper to the machine. Reconnect this harness plug to matching plug on machine harness. Reassembly is reverse. Hope this helps.
Aug 21, 2009 | Canon NP 6050 Copier
Directions on how to reassemble the recoil or
You need to specify the brand of engine . First some of the re-winders on Briggs are NOT SERVICEABLE. The whole unit must be replaced .OTHERS can be R& Rd .Please be more specific
Jul 11, 2009 | Garden
Anyone ever have a problem with 929's frying harness connectors at reg/rect plug?
If the plastic plug connector is getting hot, it means you have a bad connection there. Try disconnecting the plug and dip the ends in a small glass of pool acid then rinse them in water. This will clean the connectors. Now slip a small screwdriver around the female connectors to tighten them around the male connectors. Spray a bit of WD40 into connectors and reassemble.
Jul 07, 2009 | 2001 Honda CBR 929 RR Fireblade
Oil leaking out of valve cover gasket
It is a Valve Cover Gasket. You can get a new one at any Auto Parts Store. To make this repair last longer, Do not get the Cheap one, Get a Felpro Gasket and it will Quadrupel the Gasket Life. Please Rate My Response! Thanks!
Jan 30, 2009 | 2001 Kia Sportage
Drain gas heater for winter
On the side of the heater, you will see the water connections. Directly underneath them, on that black component that they attach to, there is a drain plug of some description. It may be a draincock, or just a plug. In either case, simply open or remove it to safely drain your heater. In a pinch, you could also disconnect the water connections at those unions (the big grey connectors), but they can be fussy to reassemble, and you run the risk of losing the o-rings.
Sep 27, 2008 | Hayward 250kbtu Ng Pool Heater - Inground
Canon iP90 Printer Problem
take printhead out and put cleaner or turps on gauzes, dab off with paper towel, reassemble and run clean programme - this worked for me and from no black output I ended up with full function printer
Jan 02, 2008 | Office Equipment & Supplies
Xerox Phaser 8500N Printer Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
