Question about Philips 27PT643R 27" TV
My Philips 27pt643r 27" TV has a high-pitched whistle
It's worst when it's first turned on, but persists throughout it's operation. It makes a very high pitched whistle sound that can get quite annoying. Any help would be greatly appreciated!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Philips Master
  • 848 Answers
My Philips 27pt643r 27" TV has a high-pitched whistle? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1942LGR3P 715G1813 1 Philips ADTV1942LGR3P Power Supply Backlight Inverter
Posted on Feb 28, 2015
  • 35 Answers
This is the line lin coil needs replacing
Posted on Sep 04, 2009
Is a high pitched whistling sound at idle a vacuum leak or what?
hissing vacuum leak at idle, louder with open throttle ...
? 1:43
https://www.youtube.com/watch?v=tFoybr865n4
Jun 27, 2010 - Uploaded by fenixus
hissing vacuum leak at idle, louder with open throttle ... i know that my camera is poor and microphone suppresses high pitch ...Hi, my kia picanto engine also sound hissing/humming duringidling with open throttle. ... Loud whistling noise 2000 jeep wrangler 4.0l - Duration: 4:01. by Nasrac72 16,158 views.Missing: vt750c
A Whistle or metal sound with firing... - Honda Shadow Forums ...
www.hondashadow.net > ... > Technical Discussion
Jul 11, 2008 - ... under load (accelerating), that there is a small whistle or even 'tap on metal' high pitch sound ... Pics of my 2008 Shadow Aero 750 (VT750C ... loose bolt vibrating
Feb 29, 2012
High pitch whine
Jul 21, 2009
More results from www.hondashadow.net
Dec 25, 2015 | Goes Motorcycles
Sounds like air is shooting out when accelerating. Could this be an exhaust leak? Plugs, coils, hoses seem fine. Noise is coming from passenger side under engine sounds like.
yes could very well be an exhaust leak.but that should be kinda loud and annoying..also u could have a slight whistling sound coming from ur air intake hose coming from air cleaner box to ur intake or throttle body or ur air inlet goin to the motor. when the motor is accelerated it would produce a high pitch sound like a whistling .hope this can help
Jun 28, 2015 | 2001 Mazda Tribute
1985 toyota mr2 engine noise
It still could be the throw-out bearing. When going bad, they have a high pitched whine or whistling, and if bad enough, could imitate a vibrating sensation. IDK, I would have a mechanic there listen to it.
Jul 12, 2012 | Toyota MR2 Cars & Trucks
2004 honda odyssey making whistle noise
I know this original question was written quite a few months back but I was wondering if you ever found out what the high pitch sound was. I just purchased a used 2005 Honda Odyssey and it is doing the exact same thing. Any advice?
May 15, 2010 | 2004 Honda Odyssey
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
High pitched whine/whistle on startup - 2003 Toyota Sienna
I have the same problem like yours but what i did is to replace the alternator and now its so quite no more high pitched sound. You may used belt stress fluid but its only last for few seconds then sound comes again. I replaced it with refurbish part alternator.My sienna 2005.
Dec 21, 2008 | 2003 Toyota Sienna
Humming noise
If this is like my unit it is a high pitched squeal. I received my unit as a gift for Christmas 2007 and I thought it was defective. I contacted Homedics and they sent me a replacement but the problem persisted. As licensed amateur radio operator I am versed in electronics so I decided to track down the source of the noise. It turns out that the 16VDC power adapter is the source of the noise. It is what is called a "switching power supply" and is unfortunately not well filtered causing the high pitched squeal. I was able to get rid of the noise by modifying the power adapter and adding a 2200 microfarad capacitor in parallel with the output. This filters out the high frequency ripple and gets rid of the squeal. An alternative solution would be to search the Internet for a better 16VDC power adapter. It must supply 2 amps of power and have a 5.5mm OD/2.1mm ID center positive power connector.
Nov 09, 2008 | Homedics iSoundSpa Max Clock Radio with...
Occasional 'whistling/whining' from back of TV
I wonder if there is enough air circulating around your equipment?? My DVD recorder makes a sound unless I open the doors on the cabinet that contains all of my equipment. The cable company says it is a fan to cool down the units.
Jan 30, 2007 | Bush WS6671 28" TV
Philips 27PT643R 27" TV Logo
469 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
