Question about Kenmore Washing Machines
What makes a series III washer stink like stagnant water?
  • 4 Answers
J. Garber:
ALL washing machines will build up deposits of gunk in places that you cannot see or readily access. In top loaders, the typical place is underneath the agitator and on the inside of the wash tub (part that holds water). This "gunk" typically consists of body oils, detergent deposits, calcium deposits, hair, dust, dirt, etc. This stuff gets and stays wet. Wet and warm plus "gunk" equals smells. Top loaders can easily solve this problem by removing and cleaning the center column and agitator, then super chlorinating a batch of wash water (no clothes). Fill the washer, putting in three or so cups of bleach, let sit for an hour or so. This should clean the tub. Leaving the top cover open will also help as well as washing smaller batches of clothes more frequently. I have also found that infrequent use of a washer will frequently cause the the residual wash water in the pump(s) to go stagnant. Running a quick small rinse before washing clothes will solve this problem. Front loading washing machines typically have a cleaning cycle and specific instructions as to how, as well as how often, to clean the machine. Have you read the operating manual? I find that leaving the door open and running a fan that blows air inside the machine for an hour or so after washing also helps dry out the machine and keeps mold and bacterial action down by drying out the machine quickly. Keep the door open if at all possible. Removing and drying the detergent dispensers as well as the detergent dispenser opening also helps. Changing detergent may also help. Most front loaders recommend HE detergent. Use the absolute minimum amount of detergent necessary to get your clothes clean which is often a couple of ounces or less. There are also products that claim to clean your machine and eliminate odors, but I have no experience with them. Keep it dry. Keep the door open. Use a fan to blow air around and dry the machine out. Run the cleaning cycle as often as neccesary.
Posted on Sep 04, 2009
I have a fisher and paykel dishwasher. 2drawers. Just ran. Stinks now and when I take out bottom stuff, stinky stagnant water inside
Do a hot wash with 2 cups of bleach in the dishwasher. No other chemicals, just bleach. It will kill the mold and clean it.
Aug 18, 2017 | Fisher and Paykel Dishwashers
Washer stinks. Water seems to be stagnant in bottom. Just ran??
There is a cleaning process for those and you should perform it frequently. First you wipe the whole inner seal around the door underneath and next to the drum,. Then you put one cup of bleach in the drum and nothing else and set it on high temp and max load size and run it.
Aug 18, 2017 | Washing Machines
Hi my zanussi 1221w washing machine stinks. I regularly empty and check the pump filter and the emergency drain. I have used calgon, bleach 95 degree empty wash cycle but it smells like there is a dirty...
check the door boot just inside the door for dark spots on the gray rubber boot and the drain hole in the boot it can grow mold where the water stands in it from previous washings and this mold will smell like raw sewage from all the soap and softener that aids in mold growth
Jul 22, 2010 | Zanussi FC1200W Front Load Washer
Our front end loader stinks and we have to leave the door open. We have the exact same problem where I work. How do you get the smell out?
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
May 21, 2010 | Kenmore 44042 Front Load Washer
Washer stinks like stale water in basket area
pour in small amount of clorox to kill bacteria that stinks.
May 19, 2010 | Kenmore 24032\24036 Top Load Washer
Stinky washer
I had a similar problem with odor. I ran the washer on hot with a few cups of vingear in the detergent, bleach, and fabric softener trays and it helped a lot. Also, be sure to leave the door cracked open when you remove wet clothes, so the inside of the washer can air dry.
May 05, 2009 | Frigidaire Affinity ATF8000FE
Smells of stagnant water
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=2349
Had the solution for me and LG doesn't stink anymore.
Aug 23, 2008 | Dishwashers
Clothes stink after being washed
run a empty load of just bleach and keep the door seal wiped down plus when your not using it leave the door open
Jan 11, 2008 | Washing Machines
Washer smells like stagnant water
Open the door and let it air dry between washes doesnt have to be wide open but not latched either also run a hot wash with no clothes and 1.5 cups of bleach (pour bleach in the tub after it fills not in the bleach disp)
Sep 28, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
211 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
