Question about Hotpoint Refrigerators
Hotpoint Refrig Model STX14CABNRWW is freezing food in refrig section
  • 32 Answers
Check the setting on the temperature control some one may have bumped it and set it to a colder setting.
Posted on Sep 04, 2009
MY GE MONO SIDE BY SIDE REFRIG,MDL ZISS480DRSS IS FREEZING THE REFRIG SECTION.THE TEMP READ SAYS IT IS NEARLY 80!I THINK IT MAY BE REACTING TO THE TEMPERATURE DISPLAY AND TRYS TO COOL IT DOWN.HELP!
Here are possible parts that could cause the problem
GE Refrigerator Freezing Food but the most common is the diffuser/damper that got stuck open and cold air from freezer continously coming in to the fresh food side.
Nov 22, 2017 | GE Refrigerators
Hotpoint frig cxs25gr freezing food
Have you tried adjusting the cooling level? Does it still freeze on other settings? Is this a new or older refer?
Jul 28, 2012 | Refrigerators
My refrig is freezing items on the refrig side.
likely a bad temperature control. also, some model GE's have a bad fresh food inlet cover, that fails to cutoff airflow from the freezer.
Feb 19, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Whirlpool Model ED5SHAXML12 is freezing food in refrigerator even when dial is at off. Happened from one day to the next.
At the refrig controls , the freezer control , controls how much air goes into the refrigerator section . Open the refrig door , and up at the top left , put your hand over the damper (air vent) . Turn the freezer control from high to low , and feel the difference in the air flow . If you turn your freezer control to a lower setting , less cold air will enter the refrig . Think of it as : the freezer control adjusts the temperature , and the refrig control , tells how long to run the compressor . In actuality , this is how it works . However , with the dial (refrigerator thermostat) in the off position and refrig still running , this indicates a bad thermostat . Pt # 2198202 .
Sep 09, 2009 | Whirlpool Refrigerators
Fan cycling low and high
The freezer fan slows down due to the refrigerator section being at the desired setting but the freezer section still needing coolant . If the refrig section needed more coolant , the fan would speed up , forcing more air into the refrig section .
After replacing the heater , it could be in the defrost cycle . The thermistors tell the main control board , " hey , we're freezing , turn on some heat " , in which the heater comes on and defrosts the coils , until behind the rear freezer panel , can get up to 140 degrees . As it gets this hot , the frozen food in the freezer , is what keeps the freezer cold . After defrost , the fan comes on and blows the residual heat into the refrig sectio , until the coils get cold again . So , if the refrig section warms up temporarily , it's normal .
Sep 06, 2009 | GE Refrigerators
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Why would my refrigator be freezing my food set at the lowest setting it can be set on
If it has a damper at the top left wall , the damper is bad or the refrig control (possibly circuit board) is bad .The damper closes to reduce the air flow to the refrig yet the freezer section can still get colder if needed . The refrig control or circuit board for the fridge control , works the damper . If you feel air coming thru the damper , it is not closing , causing your food to freeze .
Jul 18, 2009 | Amana Refrigerators
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
43 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
